i live in japan and i have been driving around all day, butchering japanese while asking "what the f**k?" at all the speed shops i frequent.
its a grid dbc 2001. installed correctly as far as i know. read on.
the hose from the back of the unit is T'd into the hose for the boost gauge which goes to the intake manifold of course.
the solenoid has one hose going to the internal wastegate actuator, the other hose is going to the intake manifold. all using the correct sized hose. the solenoid has a 3rd hole, which i left open, per the instructions. i tired it both plugged and open, it made no difference.
its hooked up to a 12v power source and grounded to the chassis. thats not an issue, it comes on and lights up real pretty.
the stock solenoid has been capped off, but i left the plug connected, so i dont get a CEL. there are no leaks.
now, what is the car doing? the same f**king thing it was doing before i spent 3 hours installing the thing. boosting to 0.6-0.7kg/cm2 maybe even less then STOCK, due to the added vacuum lines?
i crank the knob on the controller all the way to max (3bar) and it doesnt make a damn bit of difference.
basically, i am assuming the unit is just broken, but then why would the car boost the same as stock? what did i do wrong, if anything? suggestions? im about 20 minutes away from ripping it out and throwing it away.
I had a similar problem a while ago when i bought a Gizmo MS EBCII. Hooked it all up, double checked everything, then tripple checked everything. Took it out for a test drive on the lowest setting and all was good. Went to turn the boost up and saw no response. Turned up a bit more and nothing. Cranked it to the max and sweet f all. Turns out there was a loose connecter in the unit that wasnt sending the controll signal to the solonoid.
What i suggest trying to see if the actula controll is stuffed is hook a syringe or somthing to the sensor hose to the back of the unit and force some air into it. You should be able to get pressures well over 1 bar, and when doing this listen out for the solonoid. If its workin good the solonoide should be ticking wildy trying to controll the boost (trust me youl hear it when it works). If not then id be askin for a refund or replacment.
so pull the hose off the back of the unit, force air into it and listen for the solenoid? ill try.
tried this. reconnected the unit. nothing.
before boost controller install car boosts .7bar
after boost controller install car boost .5bar and its not adjustable.
im ripping it out and throwing it away unless someones got a suggestion. at the least i gained the knowledge of installing a piece of shit so it will be that much easier when i get something that actually works and install it.
Sounds like its stuffed then, If the solonoid is doing nothing the car will always run slightly lower boost than standard as its just telling the wastegate to open ASAP.
Good luck with the next one then.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
