Item: R32 5 point Cusco bolt on half cage
Condition: Very Good
Price: $550 ono
To Fit: (What car) R32 Gtst or Gtr
Comments: Comes with all bolts, nuts, plates etc.... ready to bolt on.
Edited by Richo
https://www.sau.com.au/forums/topic/236060-r32-cusco-roll-cage/
wont fit dude
^^^ as he said mate, it wont fit! back legs sit on the wheel archs.
hmmm thats weard i put this tomie 2 door cage in my 4 door
unless my mate 2 door had a 4 door cage in it
it was easy to install as well with the 4 doors an all lol
yeah i dont see why it wouldnt fit, the chassis is basically the same as a 2 door with just another door added in to get into the back
maybe get this bloke to get some measurements to see if it will mount like the one above GTS4WD
it will fit if u make it, but it sits too far back!
if u think about it, if the car rolls, all the weight/force will go straight to the drivers/passengers head while ur back seats will be protected!
i would think the 4 door and 2 door have the same floor pan
it bolted to the same place than the 2 doorwe had them next to each other
strate out of 2 door in to the 4 door same holls same place
and it looked the same
but i cant rember where the top bar went over the head rest in the 2 door
but my seats are just a bit forwared than normal in the pics
also the rear door handels just hit the cage when i close them
Edited by dreadr31
yeah from memory both 2 door and 4 door cages will fit each other, if you look at the size of the front doors from 2 door and 4 door, the 2 door is longer,
so if the 2 door cage sits at the pillar it will sit a bit behind the pillar in a 4 door, but will still connect to the wheel arch and then the distance to the dash will be the same as it sits further back,
so it should fit 2door and 4door
JV
  • 2 years later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
