As the title says i have fumes coming from my closed petrol cap. I found that the nozzle that the cap screws into in the tank is loose and i pulled it out by pulling on it lightly. What can i use (that is safe to use in a petrol tank) to seal it back in place? Can i use urethane?
https://www.sau.com.au/forums/topic/236248-fumes-from-closed-petrol-cap/
i had the same problem, when ur car gets complianced they have to change the socket to an unleaded. They usually just apply glue and stick it in. Usually after time itll wear out causing fumes to come out and not hearing that whooosh sound when u open your cap.
I used "silkaflex" its around $17 but i got it for $12 :P at supercheap autos.
Hope that helps mate :(
Cool thanks mate, yea it looks like they used some shitty glue to stick it in.
I had the same issue... started to leak and then one day broke off.
I used some stuff called Knead-It... it's kinda like a plasticine consistency until it goes hard... then it goes hard as a rock. I'd be worried with silicone based adhesives (i.e. sicaflex) as the petrol might dissolve it over time...
http://www.selleys.com.au/Selleys-KneadIt-Steel/default.aspx
You can get it at Bunnings or whatever... lol one of the suggested uses on their website is "Repairing a hole in a fuel tank".
Fantastic stuff.
You have to use it to believe how strong/hard it sets!
Hey,
I've got the same problem and it's been bugging me for years....
Just a quick question, besides the fuel smell is there anything bad that can happen with the tank not pressurising?
Thanks,
Peter
Hey,
Thanks,
Peter
About a week before I broke the nozzle off, i filled up completely. When I got home I got out and saw a big red stain down the side of my car! The petrol had leaked out under some 'spirited' cornering :dry: I saw what had happened and washed the petrol off, but didn't have time to do anything about it. The next week, I only put in half a tank just to be careful, and as I was screwing the fuel cap back on, the whole nozzle came off in my hands!
lol same thing happened to me, looks like this is common problem! Also everytime i start the car and look into the drivers side mirror i see fumes from the petrol cap...
Looks like i'll be getting some of this Knead-it stuff this weekend... Good one thanks mate.
Yeah it's good stuff... you've gotta work pretty quick though... from what I remember (this was over a year ago now...) it's like 10 or 15 minutes until it's 100% set... but the last few minutes it's almost set anyway and it's pretty hard to work with!
same with me... looks like im off to bunnings..... stupid Q as i cant really look cause my car not here atm, but how can i access the section that needs to be stuck back on? is it only the part behind the fuel cap? or is the problem further down the pipe?
For me it was just the little tube that the cap screws onto with the reducing hole/flap so that only an unleaded nozzle fits in. If I remember, I'll take a photo of it tonight... not that you can really see much because it's all covered in Knead-It now!
I work with knead-it quite abit, get a spray bottle and wet your hands and the knead-it (just a couple of squirts, not to much) and it will give you more time to use it and really get the two compunds mixed before you use it.
When u unscrew the fuel cap, youll see the peice that holds the cap on, its the round peice of metal which has the little spring flap on it for when u insert the nozzle etc. you cant miss it :(
Mine was on fairly tight as the glue was still good, thats why i questioned if the leak was coming form there, even though i could see the fumes coming out from there. But i then came to the conclusion that the glue proabaly didnt go all the way around, so i got pliers and wrapped a cloth around so i wouldnt scratch anything and just gripped on the metal bit and moved it around abit, and eventually it became loose, and yeh i was right the glue was good but they just didnt properly apply it all around, so some air would escape.
I then stripped off the old glue, and then put some glue on the inside of the tank mouth and then applied a generous amount on the back side rim of the metal bit i pulled off, then stuck it into the hole and held it down tight for abit and left it over night to dry.
I then filled her up the next day and closed the cap, you should hear that clicking noise when u tighten it all the way, that means the metal bit u glued on is dried and secure. when i got hom i opened my fuel cap and WHOOSH, lol i never really knew how much u can miss that sound :D
But hope you guys get ur problem fixed, lol just try not sit there for hours opening and closing ur cap after its done, might get high on the fumes :D
Here are some pics I took just now... I know the quality is crappy (just the camera on my phone) but at least you can get an Idea of how I used the Knead-It to fix it. And yes... this is NEVER gonna come off :)
If I had known what the Knead-It would be like, I would have been better prepared and made it look a lot better... but once it's set theres not much you can do! I would have liked to get it much smoother and looking more stock... but this is how it is so that's how it's staying!
At least it doesn't leak or anything... and yeah, you can tell it's a good seal when you open the cap (especially on a warm day) and hear the 'Woosh!'.
post-26444-1221569747_thumb.jpg post-26444-1221569810_thumb.jpg post-26444-1221569879_thumb.jpg post-26444-1221569924_thumb.jpg post-26444-1221570076_thumb.jpg post-26444-1221570124_thumb.jpg
Edited by Samon
wow your petrol hole is so small, the nozle hole in mine is about 5 times bigger..... which is the original one???? the big hole or the one pictured above???? also it doesnt cause any probs, i still hear the woosh when i open it...
mine doesnt spill with spirited cornering either. but wen i start it i look in the mirror and can see the fumes coming from the petrol cap.
thanks all. hoping to get my car back this arvo and get some kneadit onti it. lol.
er...
i dont even have that... and i dont have fumes / smells coming from mine?
Nor does it spill at full tank when i take hard cornering?
explain anyone???
Well you may have the original Japanese filler... which would have sealed perfectly as designed. It's just that when complied, they're supposed to change it to one that only fits the Australian Unleaded nozzle, which is not always done so well, hence the leaking and breaking off. If it wasn't changed, then it's not likely to leak!
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
