Just wanted to clear up an issue I have recently came across and hopefully help out others in the same position.
Saturday just gone I was pulled over in my R32 GTS4 and defected for my front ride height being too low - ride height being the distance between the centre of the wheel cap to the bottom of the wheel arch.
The cop quoted the requirement for an R32 turbo as 360mm all round, leaving me a good 20-30mm too low at the front. It was recommended by a mechanic that I get confirmation from regency about ride height as he thought I looked alright.
Official ride height issued regency -
Front: 345mm
Rear: 355mm
Not the 360mm all round as suggested by the issuing cop!
At this stage I was a bit peeved that I got defected for something that did not exist???? Got onto the police and they were unable to say where the first cop cop his measurements from. Long story short a cop came to my place and remeasured by height and ended taking off my sticker - no longer defected!
For any defect I would suggest contacting regency yourself and asking for official confirmation on all info regarding your defect. Could save a lot of time, hassle and money!
https://www.sau.com.au/forums/topic/236312-defect-information/
  • Replies 51
Posted Images
Regency is the suburb location of Motor Reg where defects are inspected/cleared. South Aussy's have always called 'that' location Regency.
I might have to give them a buzz as 360mm ride hight sucks. I want to drop mine slightly.
Mine with std suspension was 355 front and 360rear full tank of fuel.
also look at the rulings. might be a diff ride height from turbo and non turb cars. as well as the pre 1990 models maybe different too.
ring vehical standards and ask for clinton 1300 882 248. he is a good bloke that is rather cluey. ive delt with himmany of times and always came out with a good result.
Front: 345mm
Rear: 355mm
woh, im surprised they didnt come to urs and double defect u for other stuff :down:
Damn that cop to hell. If it's your job to dispense the law - you have to know it. Quite simply that cop is an idiot. Unfortunately idiot cops are the norm nowdays.
I'm not sure.. I believe the minority of police spoil it for the minority. Much like the minority of import drivers spoil it for the majority in the public eye.
Today for example.. Police usually don't blink an eye but today just one little fat dude in an under cover car decides to stare as he drives past while I'm sitting at a round about.
Car doesn't look modified; 100% stock from the outside so really no reason. I haven't had that for quite some time. The last time I remember being stared at was a good few years ago.
He was probably one of the gtr bathurst haters. :)
Joel stick a GTS4 sticker on your car that will allow 345 and 355 :)
Pete its actually Fr 340 Rr 345
SUSPENSION
Transport SA
September 2003 Modifications to Passenger Cars, Car Type Utilities and Panel Vans Page 15 of 25
A vehicle's suspension system has been designed for adequate strength and durability as well as its level of ride,
comfort and handling. It is acceptable to fit upgraded springs, shock absorbers or anti-rollbars provided they
are correctly fitted and suitable for the vehicle. Some vehicle manufacturers have optional suspension
equipment available.
When lowering a vehicle body, either front or rear, the limiting factor is the clearance between the rubber bump
stop and the corresponding metal stop. This dimension must not be reduced by more than one third of that
specified by the manufacturer.
Transport SA has a list of acceptable suspension and eyebrow heights (the measurement from the centre of the
wheel vertically upward to the edge of the mudguard) for most passenger vehicles and can be contacted to
verify if the ride height of a vehicle is within acceptable limits.
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
