Hi People , Im looking at buying a skyline , now i have a choice of a R34 GTT 4dr or a R33 Gtst 2dr .Now the R4 is a auto aswell where the r33 is a manual. They look nice and are both in mint condition. The R34 has 73.000 ks and the R33 has 43 .000 km. R34 has no body kit and is stock as a rock, where on the other hand the R33 has a body kit and exhaust and suspension. Oh aswell is there such thing as a Type R R33 gtst. the R33 is 18990 and the R34 is 17990.
https://www.sau.com.au/forums/topic/236677-need-help-r33-or-r34/
don't think there is a tyre r model.
i reckon get the r33 cause auto on r34's jsut aren't up to par unless ur just thinking about cruising.. but judging by that price...thats a huge rip off...theres many others that are similar for much less..unless u wanna spend that much?
Here is the R33 im am leaning towards. but i have kids aswell and the wife likes the idea of the 4 dr , but i think you only get one chance at this so i think get what i always wanted the r33.
o.k i just had a look on carsales.com.au for skylines in South Aus...is it just me or are skylines priced above their actual value by $3000-$4000??
so much more expensive then the skylines in melbourne.
found this one
http://www.carsales.com.au/used-cars/priva...amp;sort_type=2
if you were down in melbourne u could get a fresh imported r34 gtt coupe manual for about $15,000-$16,00 complied with rwx and rego. not really sure about importers over there in adelaide either. sorry mate but i mean if ur wife is really gonna have to use the car get the r34...if she has her own car...get the 33
Edited by jakez88
welli think so..but it might be different in adelaide compared to melbourne?...i mean you can get 33 series II's from 11000-18000 but the higher priced ones are usually modified, super clean 1998 model with genuine low kms or 40th anniversary's.
i suggest you keep looking around because i know yo ucan get something similar for alot cheaper but if your sold on that one and don't mind paying the extra money then go for it.
like for 12,000 u could by something like this http://www.carsales.com.au/used-cars/deale...de&__Nne=20
for the money you want to pay for your r33 you could by a r34 gtt like this http://www.carsales.com.au/used-cars/deale...amp;Make=NISSAN
but i dunno whats available in adelaide
Edited by jakez88
Yea wifee has here own car newish vectra, which is auto your right dont want 2 auto in the family. the R33 has only low km 43,000km and they still want $18990 is this to much ?
Just sent you PM
Have you driven the R34 Auto you maybe suprised, they go good if you drive them right and turn off the traction control:)
Edited by OzCarImports
the place where the cars are is a car yard, so maybe he trying to make his money aswell, most of the private sales here are either to far away or have been hammered. Im looking for a car that i can baby, lol you know what i mean so im probly been a bit picky.
18990 for a gtst? jebus...
i was in the exact same position about 7 months ago.
i ended up getting the r34 auto but 2 door. not a single regret
its tiptronic which isnt exactly auto. leave the tcs off and you can have just as much fun in it as the manual.
^^^ +1 ... to be PICKY
Sorry for the tangent, but is a V35 out of your budget?
The R33 $ sounds excessive
Tez
Tez
+1 the V35......
But What do i know anyway I'm new to the skyline scene. The V35 is more of a Z anyways and I Love the old Zs
Adelaide prices are thousands more than over in Melbourne/Sydney right about now... for some reason within the past 6 months R33 Series II prices has dropped by quite a few thousands over in VIC/NSW but has stayed about the same in Adelaide lol
I would be seriously doubting the legitimacy of the kms on the R33 unless log books are supplied.
Regardless, $18,990 is way too much for a stockish R33. Go the R34 as newer is better. I would recommend trying to make sure the car comes with a few mods so as to save you cash later. Eg, rims, exhaust, intercooler (only if using the stock piping without cutting holes)
Edited by Swink33
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
