Wrecking a complete car in melb
r33 gtst series 2
sold items are:
headlights
bonnet
front bar + rio
driver side windows switch
center console and dash fashia
items avaliable are the rest of the car
engine and gearbox manual 80k km inc computer = $3000
front calipers and rear brakes and calipers inc discs ABS= $600
rear end complete abs = $500 inc clipers and brakes and cradle
cluster =$200
doors complete motor window and reg door hangle and lock= $260 each
rear window = $150
side 1/4 windows tinted dark= 80 each
boot lid inc spoiler = $200
3 inch exhaust from front pipe steel inc cat near new $400
18 inch gold pro N1 BLACK RACING rims with bridgstone s03 235 40 18 tyres with 60% tread on em $1000
rear tail lights = $200 pair
skyline garnish $70
rear bar = $80
complete boot carpet and side trims = $150
complete seats inc door trims = $400
mirrors = $50 each
parcel shelf = $50
interior carpet $80
seat belts = $ 150 set
roof linning = $60
sunvisors = $50 pair
front steering rack = $100
front k frame complete $150
front hub assembleys = $150 each side
left and right guards $ 100 each
side skirts $ 150 pair minor crack on one not on visable section
rear pods 400r i think $100 pair
indicator stalk = $50
steering coloum $ 70
panel cuts also avaliable
pedal box = $100
cluch cyclinder $ 70
brake cyclinder $70
brake booster $70
climate control unit $80
front floor mats $40
heater air con box complete $ 150
dash no air bags $80
steering wheel immac no airbag $60
condenser $50
if there is anything not listed just ask for it i will have it for sure
Pick up in reservior call 0402090079
all items must be sold all prices are negoable no stupid offers please want to make someting back on my loss
Edited by SXC_R33
  • Replies 87
more than welcome to come look at the rims but they look good on the car i can get some pics up later 18x8 +38
cheers in advance for pics, may be able to come have a look tomorrow
r33 gtst series 2
sold items are:
headlights
bonnet
front bar + rio
cluster =$200
rear window = $150
skyline garnish $70
rear bar = $80
mirrors = $50 each
parcel shelf = $50
interior carpet $80
roof linning = $60
pedal box = $100
brake cyclinder $70
brake booster $70
condenser $50
hey buddy wonderin if youll sell the windscreen..?? cheers..
You got s2 steering wheel that has airbag that been exploded? If so i'm after the plastic bit under the wheel.
And you got the surround that covers the steering column between wheel and dash?
PM me the prices.
Cheers
Grant
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
