V35 Headlights, V35 Grill, R33 Gtr Mines Front Pipes, 18x12.5" Deep Lip Rims 5.5" Of Lip!, +more
Item: R33 GTR Mines front pipes x 2
Age: donno
Condition: one excellent with 3" outlet, one has a dent and has a 3.5" outlet
Price: $400 for the good one $300 for the dented one
To Fit: (What car) R33 GTR may fit others but dont quote me on that.
Contact: PM me or 0401466244
Comments: Not needed anymore and I need the space
Item: Genisis 3 piece rims x2 only. 18 x 12.5" with a massive 5.5" lip/ dish whatever people call it
Age: donno
Condition: great, few light scrathes
Price: $700 the pair
To Fit: (What car) 114.3 offset unknown (they were donner rims so it didnt matter to me)
Contact: PM or 0401466244
Comments: bought these as donnor rims. I wanted to use the outter lip and transfer my Volk GTN centres.. buying a GTR cant use them anymore.
Item: V35 headlights pair, for a S2 sedan
Age: donno
Condition: good
Price: $500 pair
To Fit: (What car) V35 sedan
Contact: Pm or 04041466244
Comments: no needed, bought for a mate who ent up going through insurance
Item: V35 front grill
Age: donno
Condition: good, few scratched
Price: $200
To Fit: (What car) V35 sedan/coupe
Comments: as above
Item: R33 manual tail shaft series one (no ABS) with yoke
Age: donno
Condition: good
Price: $200
To Fit: R33 gtst manual no abs
Comments: not needed going GTR
Item: R33 gtst rear strut brace
Age: donno
Condition: good
Price: $150
To Fit: R33 gtst/GTR
Comments: no needed
Item: R33 gtst top secret side skirts from DMD top quality!
Age: new
Condition: new
Price: $250
To Fit: R33 gtst S1 or S2
Comments: no needed, going to keep the original GTR Kit once I buy it..
Edited by J'z-R33
I would take those side skirts off your hands but i have a set of 400R ones i need to sell. ;)
  • 3 weeks later...
Im no expert on wheels champ, if the above is correct they would be about an 11-11.5 inch wheels. I also have 295/40/r18 semi's I can provide for extra $$$.
Cheers
J
Still got this stuff, open to offers and I want to get rid of it all to make room in the garage for the rb26...
Thanks mate, I bought two to use the outter rim as a doner rim to make some custom volk GTN's but no longer need them as I bought a gtr instead.
Side skirts sold, rest still for sale..
Cheers,
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
