  • Replies 72
i used to play for the brahma lodge cricket club just for fun
i am thinking of playing for another club this season
nothing better then knocking back a couple of cold beers on a hot as day watching the other team slugging it out
https://www.sau.com.au/forums/topic/237096-cricket/#findComment-4148008
cricket, hmmm, I am too asian for it, too short, too little, not strong enough to hold the cricket bat (thus can't swing it properly), can't throw the ball properly (usually goes upwards for some reason instead of forward), can't run fast enough, sigh, being asian, you know..... sucks..... :blush::P:)
Edited by ArenaGTR
https://www.sau.com.au/forums/topic/237096-cricket/#findComment-4148017
I hated cricket :banana:
+1
Sorry lads, maybe im not Orstrine enuff but Cricket is like watching paint dry. Even competitive masturbation would be better to watch. Never played it cause my attention span is extremely low and I cbf being on an oval for 8 hours in long trousers... enjoyed tennis and soccer much more heh (playing soccer only, nothing worse than watching a bunch of pansies throw themselves on the ground for a free kick)
-D
https://www.sau.com.au/forums/topic/237096-cricket/#findComment-4148151
cricket, hmmm, I am too asian for it, too short, too little, not strong enough to hold the cricket bat (thus can't swing it properly), can't throw the ball properly (usually goes upwards for some reason instead of forward), can't run fast enough, sigh, being asian, you know..... sucks..... :D:P :P
hahaha make a good cricket stump but ;)
+1
-D
never played you dunno what your missing, actually i gave it up some years ago sort of conflicts with my religious beliefs :banana:
you know what i was thinking is we organise a cricket match just fun game against NS
https://www.sau.com.au/forums/topic/237096-cricket/#findComment-4148470
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
