no way keep the badges - the boot is to boring without them - maybe with a nice lip spoiler it would be ok but otherwise... I would not have taken off the SKYLINE if you are keeping the NISSAN badge - I think all badges or none at all (with a spoiler) are the only options...
  • 4 years later...
whats different about the 07 lights?
-mark
The only difference I see in regards to the '07 vs '04 lights is that the reverse lights on the '07 are rectangles.. They're clear round ones on '04 lights..
On another note, mine had the Nissan taken off, and an infiniti grill put on! I need to change that very soon, I think!
Edited by Ninja_Nate
03 to mid-06 lights
- flat face
- round reverse light
- halogen light for running light
- leds in circle for brake
- leds closest to boot lid are 4,4,4 pattern
mid 06+ lights
- they have 'recessed' areas over the lights - stove top design like R34' - not flat.
- square reverse light as stated
- led running lights in the circle
- led brake lights
- led's closest to bootlid are a 3,4,5 pattern
- boot release button on LHS light
i did a language conversion on a V35 coupe that had this badge..
the Prince skyline badge
looked pretty neat against the blue.
hey mate how much do you charge for the conversions if I may ask? And you in Melbourne I presume?
can you PM me a cost?
cheers
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
