Pig Fu(kers hey....
Ummmmmm. Interesting coming form the :
King of Rice,
The enlightened on Neon,
the wanker of wings!
and to top if off... You car is RED !!!
and your short!
and you have a funny head.....
https://www.sau.com.au/forums/topic/2372-do-luck/#findComment-44161
I'm not sure if they were giving out GTR special number 1, i think it was GTR special number 2. Anywayz i have both, sure the pages are stuck together from me wanking too much but if anyone wants them i'll keep em in the car for the next cruise.
Peak: The neon strikes back.......Return of the Neon!:lol: and LED's.....i'm really in to blue LED's at the moment.
https://www.sau.com.au/forums/topic/2372-do-luck/#findComment-45502
Looked at it last night, the full Do Luck kit including bonnet is $24k......thats right $24,000! Looking to spend some spare change Peak?
I'm currently gettin a graphics shop to cover the car in Mines stickers, just like their show cars at tokyo auto salon. Should have it done by mid next week, will post the pics!
https://www.sau.com.au/forums/topic/2372-do-luck/#findComment-46309
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
