Make: Nissan
Model: 1990 R32 GTS-T
Milage: 138xxx
Transmission: Manual
Colour: Maroon (wine red)
Complied? Yes
RWC supplied? N/A
Currently registered? Yes, 22nd March 2009
Price: $11 000
Contact: 0405416789
Comments: car is in excellent condition, serviced every 5,000kms, parked undercover, only driven on weekends now as I work in the city
Interior is mint, not rips of tears, paint is too as I hand wash only!
I have built this car with reliability in mind, hence no big power mods. Car handles perfectly on the tiens.
Modifications:
ENGINE
- Front strut brace
- Just Jap Intercooler
- Blow off Valve
- 3" Exhaust
Suspension
- Tien Super street coilovers
Interior
- Alpine Head Unit with iPod adapter
- Nismo gear knob
- Momo steering wheel with quick release
- GTR seats
- C's Short shifter
- Alarm + immobilizer
Exterior
- GTR body kit (from JSAI)
- 16" P1 racing rims
- New front brake pads
Extras
- R32 GTS-T stock rims with tires
- R32 GTS-T stock seats
- R32 GTS-T Stock front bar
- R32 GTR stock fuel pump (unfitted)
Walk around
https://www.sau.com.au/forums/topic/237461-1990-r32-gtst-11000/
