I wanna hear from anyone running this setup on thier car???
boost range/power
i want big power with least amount of lag not sure what turbo to change too???
I wanna be able to drop a nice burnout without dumping the clutch at 5000 lol
HELP ??????
https://www.sau.com.au/forums/topic/237756-rb20-with-gt30-450-hp-turbo/
how much power are you chasing?
a 450hp GT30 is going to be choked beyond belief to drop it down to 450hp...
HKS 2835 comes to mind... forget what it is in Garrett terms but the others here will know
im not looking to make more power just want it lower down in my rev range
the 2835? what power is it capable of and does it spool up earlyish?
do you think a gt30 450hp is beter than a t-d o6?
might try the 3071 or td06
i really dont wanna spen the money and then be un happy
with the smaller turbo's i still wont come on full boost till like 4000 right???
its been so long ago that my car was stock
