Hi all,
ive been having some on going issues with my AFM's on my R32 GTR for a little while now (havent had the money to fix). i pulled the top one off just to have a look if there was anything obvious. there wasnt, so i gave it a clean and threw it back on the car. now when i go to start the car it wont fire. all that hapens is it cranks but wont fire up.
so im just wondering if the AFM would actually cause it to not start like this, or could there be another problem? as far as i can see, i havent left anything off when i put it back together.
any help on the matter would be greatly appreciated.
cheers,
matty.
https://www.sau.com.au/forums/topic/237978-gtr-starting-issue/
- Run a diagonostic code from your ECU.
- If you suspesct its the AFM, open it up and check for dry solder joint (there is a guide in the DIY section)
- Check sparkies, Coil Packs
- Check fuel pump
cool.
i just put a set of splitfires in last week, and plugs a couple of weeks prior to that, so i hope its not them...
i think the fuel pump is ok. it fires up when ignition is on, then when im cranking, i can smell it from the engine bay...
im going to have a look at the DIY section.
just out of interest, there isnt an earth wire that attaches to the AFM that i might have mist is there?
well ive replaced the afm's, but to no avail. she is still dead to the world. i really dont know where to go from here. ive checked for spark, fuel, and ive checked every single fuse in the car. i even disconnected the battery for 10 minutes to see if it would reset the computer, but no dice there either.
im running a power fc (no hand controller), is there some way of doing a code check to see if there is a fault with the system?
other than that, i am at a loss...
PLEASE HELP ME!!!! :wacko:
cheers, matty.
Hi Matty, the first and easiest thing to try would be the ECU itself. If you still have the standard item install it and see if you have any luck. Failing this, and without a diagnostics machine it's simply a game of elimination. A few other common items that will cause this are:
  • Cam Angle Sensor (CAS)
  • Ignition Module
PFCs don't have a "reset" mode, like the factory ECU does.
How old is the battery? Do you have enough "juice" to get it started (try jumping from another (running) car). (I had the problem of not wanting to fire, even with a battery pack. Needed a jump.)
unfortunatley i dont have the factory ecu. ive checked the ignition module and its fine. is there a way to test the cam angle sensor?maybe with a multi meter or something?
the battery itself should be fine, i put it on charge overnight but it made no difference.
im really stuck on this one... :D
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
