  • Replies 113
kell, im not sure what you have planned but as its a long weekend i would recomend taking the "back" way to victor, via aldinga, around the hills past the myponga turn off etc as there is never cops there and the main road will have a speed camera every 15km's and most likely that bloody plane in the sky taking ur speed down (i shit you not there is a plane along that road on certain days)
pm please, im almost to victor already but might be up for some photos enroute, and yes take the back way it will be a cop doughnuts and coffee fest on a holiday,
the plane is a cessna 172 a white one, i can get the rego numbers off it if you want..lol... i use a police/aircraft scanner to know when its up and can see it pace me thru my sunroof...lol. i see it all the time running up and down both roads to and from victor from my patio as well...lol. also watch it the cops in aldinga /mclarenvale they use a radar hanging on the outside back window of unmarked/marked cars while moving?(just like the USA assholes). and long range laser hidden in the trees on south road as well. be warned !!!!
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
