Hey guys, I own an r32 gtr skyline which is running the standard bush bearing steel wheel turbo's im pretty sure.
the solanoid in the boost controller is cactus so i cant set my boost. i've owned the car for 7 months or so and the past 2 weeks i've driven it hard, taking it over 5000rpm. before 5000rpm it probably only hits 13 maybe 14psi and its only driven on the weekend.
on saturday i went to overtake somebody and i put my foot down in third hitting 7500rpm and hit 1.8 bar boost. since then when my turbo's spool up i hear a high pitch whine. I pulled apart my car today to inspect the intercooler piping and the BOV to see if that might have been the problem but they all seem fine. it has blown blue smoke but there wasn't much and its only happened once and that was a few weeks ago.
I suspect that its an oil seal, bearing or the wheel in one of the turbo's but i've had a mate have a quick check over it and it doesn't seem to be driving any different. still feels just as smooth and powerful and doesn't feel like im losing boost.
if anybody has any ideas or input it would be much appreciated.
and i know running the boost controller without a working solanoid is stupid but its only a gizzmo ibc, not worth it when i have an Apexi AVCR on order.
cheers :nyaanyaa:
Edited by gtrnismo
https://www.sau.com.au/forums/topic/238171-turbo-problem/
the stock units are ceramic, not steel wheels
remove the boost controller you have and run off the actuator, at least you will have human-normal level boost instead of unlimited boost
your current setup is unlimited boost
https://www.sau.com.au/forums/topic/238171-turbo-problem/#findComment-4164014
they're the n1 steel wheel turbo's. I've got a Nismo edition r32.
https://www.sau.com.au/forums/topic/238171-turbo-problem/#findComment-4164122
http://i459.photobucket.com/albums/qq320/kaluah8123/turbo.jpg
any other ideas out there?
the whinning noise u can hear is the turbo on the way out speaking from my experiences anyways.
u are much luckier then i am i could hear this whinning noise also didnt no wat the go with it was but i gave it a gut full in 2nd only to hear a high pitched pop which was the wheel shooting down my exaust with a lil cracking noise which was the wheel blowing a hole thru my cat:) :P:D
this was also on the standard turbo.
btw it was cause by the dodgy bleed valve where the bolt rattled out giving me unlimited boost for only a short while go it pulled harder ohh the memories: :/
the standard turbos dont really like boost much mate so i would rip ur bc out and run just off the actuator as said above cos u are going to be up for a new turbo soon
this is what your turbo will look like with unlimited boost continuing.
P.S i retrieved some pieces of the wheel out of my exaust as a keepsake
Edited by Hunting Lions
https://www.sau.com.au/forums/topic/238171-turbo-problem/#findComment-4168387
yea i assumed it was the wheel. i took my car for another drive last night and it sounds rotational. i then put it in nuetral and gave it some revs and didn't hear the sound because my turbo's dont spool up in when out of gear. thanks mate for the information. i think ima just buy a couple new turbo's. probably hks gtrs turbo's :)
https://www.sau.com.au/forums/topic/238171-turbo-problem/#findComment-4168777
my turbo's dont spool up when its in neutral. lol. i've hardly driven it since buying it and have no idea how its set up. guy i bought it off told me it was an 11 sec car before it came to australia. it has an apexi power fc pro in it, dunno what other shit is in there. wont find out until i pull it all out.
https://www.sau.com.au/forums/topic/238171-turbo-problem/#findComment-4168958
sorry mate but i doubt it wouldn't spool up in neutral, it would take a fair bit of engineering to make it happen and what would be the point anyway?
https://www.sau.com.au/forums/topic/238171-turbo-problem/#findComment-4169147
well when i rev it i hear no turbo's and no blow of valve. sorry people im not a car expert, know f**k all about them tbh. so i assumed that they're not spooling up. or are they spooling up and not making boost?
Edited by gtrnismo
https://www.sau.com.au/forums/topic/238171-turbo-problem/#findComment-4169635
lol at the turbos not spooling in neutral
so your engine stops producing exhaust gases in neutral as well does it?
There's not much load on the engine so, you will get very little spooling as per previous posts.
Watch your boost gauge if you have one....if doesn't exactly do much in neutral
https://www.sau.com.au/forums/topic/238171-turbo-problem/#findComment-4171441
*Dave here*
you should check the end float on the turbos asap. any noise is bad. but if you catch it now you might be able to save your motor.
you have to pull off the suction pipes to see. and hopefully they are steel wheel ones.. lol.
https://www.sau.com.au/forums/topic/238171-turbo-problem/#findComment-4174372
Boost created is relational to load (amount of throttle used).
How much throttle do you use to rev the engine in neutral?? (rhetorical question).
Small amount of throttle = small amounts of exhaust gases, which in turn means not much boost created.
Some "know-it-all" people should probably do a bit of research before acting all big and mighty with their "opinions"
If you're turbos are creating more boost than they are supposed to then it is related to your wastegate. The boost-solenoid controls the signal to your wastegate actuator so it is most likely the problem.
Best short term solution is to remove the solenoid so the actuators work on their own without the solenoid, and have the turbo's inspected by a reputable mechanic.
https://www.sau.com.au/forums/topic/238171-turbo-problem/#findComment-4175394
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
