On the second show, they revealed that the R35 GTR was speed limited to 180kph, which is why the GTR has now been knocked off by the Ford GT Production car. Apparently it was stuck at 180 most of the way down the straight.
I like the show. I prefer the original pommy Top Gear, but 2x shows = more Top Gear to watch!
So where can we see uk top gear now when sbs is showing aus version? is it on foxtel?
yeah i recorded the last episode on my dvd recorder. seriously not worth the watch in my opinion. holden vs ford with no clear definition between the 2. none of the drivers knew how to drive either car on the track, then a race who can unload my rocks with a ute.. fail!
if anyone here is on internode/adam internet (Or any other isp that uses PIPE)
(End nerd rant)
then pm me your email and i'll give you an invite for tracker.peeringsa.net which has both episodes on there and im guessing any further episodes that crop up.
(End nerd rant)
Wouldnt mind that... my ex-boss is the owner/founder of PIPE (dickhead of a bloke tho) and I'm with Node :)
-D
I'm south, but i work in the city. i'll be around north east of the city friday afternoon aswell
I'm south to......... PM sent
(End nerd rant)
I'm with Adam............PM sent
+1 it was pretty lame. That Ford GT was awesome!
just got the first 2 episodes last nite and almost stoped watching it. i couldnt handle how much they were trying to copy the original, and the presenters are hardly what ild call ausie. but oah well its more top gear i suppose. i had to go back n watch the r35 hit the track a couple of times, sounds sikm8.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
