Damo_R34 Posted October 1, 2008 Share Posted October 1, 2008 fecked turbs will pour out white smoke. hey Chad, didnt your piston jam in a perfect position so you could keep driving it? Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4168933 Share on other sites More sharing options...
SLED Posted October 1, 2008 Share Posted October 1, 2008 leaking intercooler hose will.....and also blow black smoke though Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4168947 Share on other sites More sharing options...
SLED Posted October 1, 2008 Share Posted October 1, 2008 how did Adrian's post go before mine when it was written 2 mins after, lol Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4168951 Share on other sites More sharing options...
rad100 Posted October 1, 2008 Share Posted October 1, 2008 checked ur coilpacks? that makes wrx idle if one is missing! checked ur plugs? coz if its missing it would be blowing black smoke for unburnt fuel! Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4168946 Share on other sites More sharing options...
craig R33 Posted October 1, 2008 Author Share Posted October 1, 2008 coil packs are near new splitfires. i checked all piping and appeared A'okay as i said, simon has it now, i cant check anything, ill keep ya all posted as soon as i find out. cheers for the help all Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4168955 Share on other sites More sharing options...
Damo_R34 Posted October 1, 2008 Share Posted October 1, 2008 ill put my money on a combination of things rather than internals. With internals, they usually go when ur hammering through the rev range, i reckon u have a dud coilpack + cracked cooler pipe, like maybe on the inside of an elbow Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4168954 Share on other sites More sharing options...
DSTROY Posted October 1, 2008 Share Posted October 1, 2008 fecked turbs will pour out white smoke.hey Chad, didnt your piston jam in a perfect position so you could keep driving it? yeah, as you can see in this pic a large piece of the piston broke away but was held in place buy the rings, so under boost the piece was pushed back in to fill the whole, only blew big clouds of white smoke every now and then when i took off from the lights. Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4168974 Share on other sites More sharing options...
SLED Posted October 1, 2008 Share Posted October 1, 2008 check the deterioration of the top land Chad, looks like it had been running on bad mixtures or timing for awhile Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4168984 Share on other sites More sharing options...
rad100 Posted October 1, 2008 Share Posted October 1, 2008 how did Adrian's post go before mine when it was written 2 mins after, lol hahahaha SAU fail!!! Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4168980 Share on other sites More sharing options...
Sambo33 Posted October 1, 2008 Share Posted October 1, 2008 i had 6 f**ked ringlands in mine, and the funny thing was it idled nice and drove nicely too. it was just boosting it over 4.5k and out came the massive smoke clouds and a full catch can of oil Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4168988 Share on other sites More sharing options...
DSTROY Posted October 1, 2008 Share Posted October 1, 2008 check the deterioration of the top land Chad, looks like it had been running on bad mixtures or timing for awhile Yeah, im pretty sure the cause was a bad puel pump, its was replaced, but obviously it was to late for it and it ended up dying on me, but it also could have been a bad injector as only one piston was like that, all the others were fine. Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4169016 Share on other sites More sharing options...
Ryanrb25 Posted October 1, 2008 Share Posted October 1, 2008 (edited) Here's what a dirty injector does to a piston. Always pay's to get either brand new injectors or get second hand ones cleaned and flow tested. Edited October 1, 2008 by Ryanrb25 Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4169109 Share on other sites More sharing options...
Import S13 Posted October 1, 2008 Share Posted October 1, 2008 (edited) i had 6 f**ked ringlands in mine, and the funny thing was it idled nice and drove nicely too. it was just boosting it over 4.5k and out came the massive smoke clouds and a full catch can of oil oh man, this sounds like what my cars doing but my car idles lumpy and abit all over the place but drives alright but massive clouds of black smoke between gears under boost Edited October 1, 2008 by Import S13 Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4169186 Share on other sites More sharing options...
SLED Posted October 1, 2008 Share Posted October 1, 2008 Yeah, im pretty sure the cause was a bad puel pump, its was replaced, but obviously it was to late for it and it ended up dying on me, but it also could have been a bad injector as only one piston was like that, all the others were fine. was it one of the back cylinders......#6 tends to run on the lean side on RB's apparently......plenum design or something similar I believe Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4169362 Share on other sites More sharing options...
shy_s6 Posted October 1, 2008 Share Posted October 1, 2008 fecked turbo would cause white smoke, correct? thats only if the oil seal is broken, ive seen a few exhaust wheels come off, just causes the fuel ratios to go to shit. aka black smoke have you tried another stock bov at all? hopefiully you used decent metal gaskets for the mani to block and mani to turbs areas Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4169476 Share on other sites More sharing options...
Sinful Posted October 2, 2008 Share Posted October 2, 2008 Love all the speculation!! It's at morpowa and I am sure they will find the problem for you! I really hope it's not internally But with this sort of issue can be alot of things as mentioned above Good Luck!! Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4170173 Share on other sites More sharing options...
craig R33 Posted October 2, 2008 Author Share Posted October 2, 2008 yeah we used metal gaskets. just got a call from simon, he is also stumped, last i heard, he was gonna check AFM. i think dan is onto something with the exhaust wheel coming off.....that would explain the bad boosting sound and bad afr........... Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4170264 Share on other sites More sharing options...
craig R33 Posted October 2, 2008 Author Share Posted October 2, 2008 (edited) just got another call from simon he found a split in an intercooler pipe, he just replaced it and bout to run the dyno. *punches self in face, why didnt i check it properly, f**k head* Edited October 2, 2008 by craig R33 Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4170269 Share on other sites More sharing options...
ted180 Posted October 2, 2008 Share Posted October 2, 2008 *shoots face with gun* Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4170280 Share on other sites More sharing options...
typevu Posted October 2, 2008 Share Posted October 2, 2008 *face palm* Link to comment https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/page/4/#findComment-4170377 Share on other sites More sharing options...
