I thought it'd be good to have a bit of a list of all the sweet cars in town.
For the population there are quite a few so list em up as you see em.
I don't intend this to be just a I saw you at maccas type thing, but to let us all know when a new beasty is here!!!!
So to start:
I saw a pretty stock lookin R34 GTT Silver with no wing a couple days ago
https://www.sau.com.au/forums/topic/238255-spotted-in-alice/
  • 4 weeks later...
also possibly not YOURS??????? lol
Saw a falcon getting pulled out of the drain near Lyndavale shops.....
Looks like it went through the Payphones first , all the way across the carpark and into the drainage....Must have been flying..
  • 2 months later...
Finally got out of my commodore and into another turbo import. Goes very quick for a 2.5 tonne 4WD. Torque is very impressive :)
Have already got rid of the bling alloys and yesterday had a 3inch straight through exhaust fitted (no mufflers at all)
Same plates, so you can't miss it if you see me waving.
  • 3 weeks later...
  • 1 month later...
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
