Thanks Ben.
Based on everyone's comments regarding the CVT, I'll be buying a 3 year mechanical warranty on the car from the dealer. So, for the next 3 years, I should be "safe".
Can I ask if finding a donor gearbox, say a 5 speed auto or 6 speed manual, is a hard task? I mean, if the CVT is gonna break, I might as well change the whole gearbox.
Yes, its a pain in the a$$ task, but more importantly, expensive.
Apart from swapping the mechanical parts over, you also have to change the computer. If you are putting in a manual transmission, then obviously you need to put the clutch mechanism in aswell.
If you add up parts and labour, then you will probably come to realise you should of just bought a 5 speed auto or manual to begin with.
Everything you need to do with that CVT transmission is either difficult, expensive or time consuming.
How do I know this? I had a 350GT-8 for a few months before I came to my senses. The smoother driving experience is not worth the hassle, its just a gimmick IMO. Now I have a 5 speed auto and its fine to drive, smooth enough.
If you don't care about throwing your money down the drain, then get a 350GT-8.
Does anyone know if the 5 spd auto uses the same type of oil and if they require the same amount as the CVT?
Judging from the above, a full transmission oil change would cost more than 1k including labour!
For the 5 Speed auto use Nissan Matic D.
It is their fully synthetic fluid.
They also have a Matic J which is a semi-synthetic.
When I had my trans serviced by FTG Nissan, they used Matic D even though it says Matic J on the dipstick.
When I asked them, they said that the Matic D is basically a superior replacement for Matic J.
How much did that cost you all up and how many litres did it take?
$250 for the full service.
Just been on the phone with FTG Nissan service who was looking at the job card. (Got the D and J the wrong way around, sorry. Go for the MATIC J)
It was a flush using their machine so anywhere from 8-10L.
The 350z auto contains 10.3L in total (not just in the pan) so I presume that the V35 would be similar?
You can also ask for the additive satchel to be added ($30).
Nissan MUST add this satchel to all new auto transmissions to increases the life and performance of the trans.
Total cost as of 5 minutes ago is $262. That is a flush with Matic J fluid and also including the additive satchel.
  • 5 years later...
I know theres a few extroid CVT threads around but ill post in this one...
12L of KTF-1 CVT oil shipped from Japan for $850 (total price, including shipping, tax etc. wasnt listed as dangerous goods)
the tins bend very easily if not using the handle to pick up, so dont be surprised if they arrive with a few dents. they seem strong enough to not pierce unless really hit.
bought from here: http://global.rakuten.com/en/store/onlinestore/item/10000682/
emails were mostly in Japanese but it was easy to deal with them. just give them name, address and method of shipping, they'll email you the total price and I paid with credit card. took under 2 weeks to arrive.
cvt.co.nz were also helpful and want $79 for CVT service kit (gasket + seal) however he isnt replying to my emails any more (maybe because i told him I was buying the KTF-1 oil from somewhere else? i dunno)
I'm still asking around in Melb to see who wants to service it.
Ouch.. I imported a 20L drum of NS-2 fluid for my wife's J31 Maxima from Japan. it was $310 shipped.. and I thought that was expensive. I didn't realise that KTF-1 was so much more!
Although they refused to ship it initially, stating it was a flamable fluid and can't be shipped. I had to find the MSDS for the fluid and forwarded it to them to prove it wasn't a flamable product for shipping purposes.
  • 7 months later...
Hi all,
Im hopping some one can help with this we have recently picked up our V35 350GT8 2002, Most of the time the car is fine but twice the car has been on the Highway and twice the car has appeared to start slipping, ie. revs increase but the speed does not to the extent that the car is doing 100klm/h and doing 4500rpm (there is still drive there) at which point I pulled over let the car sit for a minute then once we had taken off it was fine.
Has any one heard of this before???
The 'Snow' Button was on my mums cars when she experienced the same problem.
Higher Revs than normal.
Make sure this is off!
  • 2 months later...
$1500 for gearbox oil?????
so no one else makes toroidal CVT transmission fluid? let alone have part numbers for it?
Correct, no one else makes this Transmission Fluid.
Only Global.Rakuten has some if you want to buy some from Japan.
I am buying mine from CVT.CO.NZ & then will compare against the Japan market...
Despite the transmission oil price, i think the 8 speed CVT is a quality transmission. You guys shouldn't be bad-mouthing it or spreading anti-CVT views just because the flush is expensive.
I mean, look how expensive Porsche maintenance is, yet there are still so many owners out there. Another example, look at superchargers, they are a great technology, but parts need to be replaced often, and often quite expensive...How come no bad-mouths superchargers? And turbo's, etc...The list goes on...No mechanical product lasts a lifetime!
If you buy something, be prepared to maintain it, through good and bad....Sounds like marriage...LOL...
For those married, you go try tell your wife "Oh, I married you thinking you were cheap to maintain. But it seems not!" ...See if you get out of the house alive!!!
That is so spot on said!!! Heheeheh
I love my GT-8 to bits ;)
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
