in regards to the top question my car before i had it rebuit was set to 20psi running everyday pump fuel it let go a month later because the head gasket blew.
a few other things contributed too but anyway dont run over 20psi unless you got race fuel
pump fuel sucks dude you will blow your 20 pretty quick if youve just bolted up everything to a stocker
im making 241rwkw now after my expensive rebuild the engine pumped out a 260kw run but we detuned just in case somethin let go
i reckon my car is capable of 280 - 300 kw if i stick some boost in it and tuned it to race fuel for a couple of passes
my other question to adam was that ive got a gt30 in mine now but its bloody laggy 5000rpm starts to com on hard
did cams make a big difference in your car?
im gonna change my turbo to the 3071r same power less lag? what you reckon?
i only ever ran bp98 in mine and from day one it was tuned on 20psi, then 24, then we went as high as 28 but from 26-28 it made no extra power so we backed it down. its all in the tune just keep it conservative and safe, dont try and push for every last hp
i dont think your headgasket let go because of the fuel, you would have had detonation and obvious signs of it on the pistons/head if it was a fuel issue
is your gt30 a 3082? i ran the .63 rear on mine and i can honestly say it wasnt THAT laggy haha for the power it could have potentialy made it was fine. 346@22psi on a tired motor is fairly respectable as far as a 20 goes.
asuming yours is the .82 rear id go about changing the rear housing befor doing cams.
yeah na pretty sure it is a .63 not sure on exact size but it is big
full boost at 5500 - 6000
my mechanic told me not to wind it up past 20psi on pump fuel. i am runnin v power
he did say ultimate is way better
i just wouldnt push a stocker that hard ay i dont even push mine to limit i got forgies and the lot in mine now
but i am gonna do a seperate tune on race fuel i reckon ill be pushing a fair bit more on that but only for like track days and sprints
im happy with a conservative 240 250 kw but still wanna bring it in lower i want full boost at 4500rpm
3071r or td06 here we come
how will a tdo6 bolt up to my car? i dont wanna buy a full kit.....
i got a gt30 on mine now but i dont even know what size the flange is
can you buy just a tdo6 turbo by itself?? what are they worth? not so easy to find ay
Between AD4M's trips to bizillion pounds of boost and trips to the drag strip, the drift guys belting of rev limiters and the abuse my car sees, i think you can say that if you keep an eye on the tune and water/oil temps then you can make a reliable 250rwkws from an RB20 with the right turbo.
Remember, RB20 has lower compression then other RBs from the factory so personally dont think a head gasket is a smart investment.
Good work on the feature AD4M, i binned my car at Sandown a few weeks before the planned shoot on my car last year. Still havent got the guard fixed so havent bothered to re-schedule.
In a sense i am envious of your TD06 setup as the larger exhaust housing allowed you to run some funny levels of boost. Thankfully i had a quick chat with the tuner of my car before i did some damage, as i was getting close to maxing out my GTR injectors when i wound the boost up 22-23psi...so thought it was fuelling at the top end that was the problem when it pinged.... it seems its the fact that my back pressure through the tiny 8cm housing was what was causing the detonation at 8k in 4th gear . Seems about 19-20psi is the sweet spot for my car and the 8cm housing :)
My mate and i both run hks 2835 pro s turbo's (3071's in essence) on stock rb25's with the same mods... Only difference is cams. I have 265 rwkw without cams and see full boost by around 3500 his car has 275 rwkw and sees full boost around 4000
just some food for thought
Guys just found out the serial number on my turbo i am still unsure of housing size think its .63 and a/r .70
serial number 700177 - 5014
ive tried to google search it and find it on the garret website but i cant get hard evidence on what it actually is??
can anyone help
i wanna compare it too a 3071r
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
