I can only speculate what happened here as I didnt see it but I sure as hell heard it and felt it. We heard/felt a rather large boom at work today, somebody went to investigate and this is the cause. I suspect, as the person had just apparently spent $2k on engine mods, a dodgy fuel rail leaked some petrol onto the battery which caused a spark and the following explosion and fire. From the photo you can see some sort of engine with a turbo, it was a commodore so perhaps one fitted with a rb30det. I feel sorry for the owner, but at the same time its a commodore :)
https://www.sau.com.au/forums/topic/23906-priceless/
    • If your head gasket lifted, you should have seen a coolant pressure spike. There's no need for a copper gasket/fire rings at 30psi. An MLS with perfectly clean/flat mating surfaces should suffice.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
