  • Replies 44
Lol guys,
I'll get dash kit from import scene , but anyone could get me someone who can make alumunium dash kit for better result and cheaper price, it would be wonderful.
Paul adviced me to mix and match red with alumunium, gold would be too shiny riaz
Give me more input, and I'll organize something for my car
Yeah that's what I meant not real one, if it's the real one it will cost me a car for that :).
Hopefully I can make decision though, I Like full retrim in red as well, I saw in the website a celica doing it , an Indonesian guy own it, the plates is PETIR, it looks awesome
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
