Hi all,
I had to replace my cluster, and now it seems that the speed is wrong, I seem to be traveling slower at "60 " than the rest of the traffic?
Just wondering if the readings can vary between cluster from different models, (Auto/Man, RB20E/DE/DET)
https://www.sau.com.au/forums/topic/239210-cefiro-clusters/
I would say that the issue is not that the clusters have different ratios, but that the cluster is out of calibration due to age.
Cable driven speedometers operate using a spring and rotating magnetic field, when they get old the spring looses it's tension and hence the speedometer reads higher than your real speed.
https://www.sau.com.au/forums/topic/239210-cefiro-clusters/#findComment-4188240
  • 6 months later...
That is a freakn really good bit of info thanks for that. Is there a easy grub screw or sum thing to adjust in real time wif a GPS to calibrate easy?
https://www.sau.com.au/forums/topic/239210-cefiro-clusters/#findComment-4550284
It's not something you can adjust yourself, I believe a specialist shop would replace the spring components with new items.
Makes sense about the auto/manual thing considering they usually have different gear ratios between auto/manual, and the speedo cable is driven from the gearbox output.
https://www.sau.com.au/forums/topic/239210-cefiro-clusters/#findComment-4552261
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
