After thinking it would be a good idea to boot it coming onto the highway yesterday and my gearbox destroyed itself in a big way, im deciding on which box to choose from. Obviously the 25 box is much stronger and larger, but will it still fit in the standard tunnell of an S13? Anyone who has a whining RB20 gearbox, pay attention to what its trying to say! :) I think the new clutch didnt make it too happy either.... The box is that bad that you cant even let the clutch out in neutral. Also what would be ballpark figure for the 2 boxes?
https://www.sau.com.au/forums/topic/23923-rb25-box-into-s13/
No you need a new tailshaft even from the rb20 box as the yoke is diff in the 33 box. Also the std gearbox mount cant be turned around as its height is different on each side. The gearbox mount is easy and anyone could make in 30mins with the right tools.
https://www.sau.com.au/forums/topic/23923-rb25-box-into-s13/#findComment-514196
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
