Item: H1 6000k HID kit
Age: Brand new
Price: $120 delivered
To Fit: Any car with H1 bulbs
Contact: By PM
Comments: This kit was ordered for a friend out of the HID group buy. But he has since changed his mind, so the kit needs to be sold.
German name Brand Helligkeit HID Kit, simplified wiring which eliminates any unnecessary confusion during install.
More than 16+ bulb types.
0.3% failure rate, compared to 3-10% failure rate of other HID Conversion kits currently out on the market, the reliability is comparable to that of OEM HIDs
Color temperature output has tolerance of +/- 100K, the tolerance is unnoticeable by human eyes
Superior lumen output compare to its competitor
Best quality burners from Hella
Choose from 6 different color temperature, you will indefinitely find the color output of your choice German name Brand Helligkeit HID Kit, simplified wiring which eliminates any unnecessary confusion during install.
https://www.sau.com.au/forums/topic/239385-h1-6000k-hid/
Bugger, these wont fit my r32 ey? cause projectors are h3c :P .. Should sell quick for that price dude.
i've got projectors and have h1...depends on year....
i don't really get the wattage thing with these...are these 35w? do they suit our cars the best or higher wattage better?
https://www.sau.com.au/forums/topic/239385-h1-6000k-hid/#findComment-4194599
Anyone experience any problems with the boys in blue after installing one of these? I mean any HID kit that is...
well they are illegal...have heard a few stories of people getting dicked for them...not legal unless they cam with the car factory and in that case should have auto levelling and washers? think thats how it goes.
but they make such a difference..everything good for our cars are illegal almost =(
https://www.sau.com.au/forums/topic/239385-h1-6000k-hid/#findComment-4195489
35w is all you will need.
https://www.sau.com.au/forums/topic/239385-h1-6000k-hid/#findComment-4195729
Got any left mate?
Hit me up Im down for a set, just also as the colours will differ from the hid to the spotties on the S2 R33 got anything that can match? or what can be done in that area
Cheers,
Steve
https://www.sau.com.au/forums/topic/239385-h1-6000k-hid/#findComment-4252089
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
