Hi guys
Well, went through regency the first time and I got 2 bloody pages worth of things to do to the car, to clear the defect. :banana:
If I had the time I would probably do everything myself, but I want the car on the road asap,
So, I was wondering if anyone know of a workshop that can do this type of work, maybe if you have had good experiences preparing a car for regency with them or something. Might need to borrow a few things off them as well, so hopefully someone that has all the stock gear for those situations.
Its nothing major, just lots of annoying little things here and there...
Cheers
https://www.sau.com.au/forums/topic/239607-workshops-for-regency-stuff/
SMOOTH GARAGE!!!! i couldnt recomend them enough and they will hook you up no prob. plus regency is just down the road from their place.
there is another place on main nrth rd, but they are WAY to over priced and everytime ive been there ive left with a bill of over a 1k :banana: so i wont even say their name haha
i wasnt going to say their name but owell.
its a shame that they are so overpriced because they do decent work and are a great bunch of people! i just cant afford to go their anymore and come out over a grand less everytime for such small things!
The infamous list:
- Horn to operate (need a steering wheel that works)
- Number plates lights (rear)
- All lights to operate
- Pedal covers to be rubber (not aftermarket.)
- Tighten front seat belt buckle
- Brake fluid level low
- Replace left indicator (broken)
- Repair rust through battery tray+skirt
- Brake hoses to be secure (need some hoses that come with the fittings that go on the clamps)
- Remove rose joints on all rear suspension + front torsion bars (fit stock gear)
- Replace LH engine mount
- Replace split rack boots
- New Gearbox rear mount to be fitted
- Rectify brake fluid leak LH front hose
- Fit split pin to LH rear lower joint control arm
- Replace worn lower shocker bushes on rear shocks
- Rectify free play LH rear wheel bearing
- Engineer Hicas lock bar as well as rear lower control arm mount (been welded back to crossmember)
I can do a few of these things, but the ones in blod I want done by the workshop.
I am waiting on a quote from smooth garage, boostworx....well I dont have 5 weeks to get in, I want to do it next week.
Any other ideas?
Cheers guys
The infamous list:
Any other ideas?
Cheers guys
Holly crap dude
the guys at regency really did write out a novel on you
goodluck with it all
Take it to Shuan at Boostworx. What's on the sheet? Maybe you could do some of it at home.
+1
Shaun is a nice bloke.
go to the site and send them a Email.
im going to boostworx wed with a list not as long as yours but alittle worse
alot cheaper than jms etc.
good luck
Edited by PREISS
hey mate,
we do this kind of work all the time, we just finished a very major defect on a customers 300zx
we have all the stock parts on the shelf so thats no problem, we can even take the car to regency and get it passed :)
if your still looking for a workshop to do the work let me know and il do my best to help you out
cheers
Steve
Edited by Nisswreck
$250 to issue a certificate for a Hicas Bar??? f**ck that!
Looks like Smooth Garage are going to take care of it next week.
We will see how that goes.
Well that answers the question I was going to ask so you can't have a hicas lockbar without it being engineered. Who did you get the quote from for the HICAS lockbar certificate? If its that much I may as well swap mine back to stock to clear defect and swap back afterwards.
I got that quote from Rory Thompson, they are real arseholes there, put the car in the hoist for 5 mins to have a quick look, I said I was going to think about it and look at other options, and he goes "just give us $30 for our trouble" :)
Yes you better put the stock back on to be safe.
hey mate,
cheers
Steve
PM Sent!
going by your list a lot of the stuff listed it should have been kept on top with if the car was mainted to a reasonable standed .
ie how can you drive and not know you have a broken engine mount things like like oil leaks .
lights not working worn shocky rubbers surley they must have been knocking a bit ?. not meaning to be rude but i see cars like this every day where i work what makes your skyline any better than a vn commy with the same probs .
it may be a blessing in disguise you got pulled over at least you will have a safer car all round when it;s fixed
    • I didn't know about induction heaters but checked them out and they look awesome but too pricey for the occasional job like this. And I'm too nervous to take a flame anywhere near there as the petrol tank is so close, although I was intrigued with the crayons suggestion 😁 I filled a coke bottle lid with penetrating fluid and raised it on the jack so the nut was submerged in it all night. Then went in with a tiny cold chisel and got it almost to the point of splitting but not quite (I didn't want to damage the bolt threads). Then I hammered a socket back on and gently worked it until I felt movement. And it's off 😀
    • I should. But it already uses too much fuel for a daily. You might note my recco for engine chnages are almost exclusively to people who have it as a weekender/summer car. I don't even have room to keep the spares for this one, let alone another car.
    • If I had "perfect R33 GTR" kinda money I would have bought one of the crazy expensive low mileage HJA cars, but I am sadly not that wealthy. I already picked this car out of various Skylines for sale locally, most of which were worse in some way. Only a few cars were actually better but also more expensive. In terms of buying a motor locally, I at least have the option to inspect it myself and juding the seller as a person, and used or freshly rebuilt engines that some people sell are actually ok price-wise. I knew the car was going to require work, but shit piled up real fast and I haven't even driven 1000km yet as the turbo started oiling like a bitch within a few weeks after I got the car.   I assume it wasn't actually me who cracked it, though there is no way to know when that crack formed and if the previous owner even knew it was there. Buying another 05U Block can be a gamble, yeah, but the cheapest PRP cast block is like twice or more money-wise, and billet is 3 or 3 times as much. For now I am most likely just keeping the current engine, as a rebuild or engine swap isn't happening right now. But I am seriously considering buying a second engine and selling mine in return. Might be a sweet deal at the end.
    • Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
