Hey,
Now that the weather is getting warmer I was wondering if someone could help me out with a couple of questions...
Firstly, when it's about 25-30°C the GTR feels noticebly less powerful. There is also a loud whining sound coming from the engine, is this simply the radiator fan spinning faster?
Is it normal for me to feel a noticeble difference in power when the car is hotter? I could certainly feel it almost taking strain today.
The temp guage in the car seems to settle at one point and doesn't really move past there so I am assuming that this is correct or is there any way to confirm this with a digital read-out?
I also noticed that on the front of the radiator there is a smaller fan mounted to it -- what is this used for? I can't seem to find out!
Thanks guys :(
https://www.sau.com.au/forums/topic/239748-cooling-the-beast/
the fan on the front is for the air con core, which is what its mounted to.
the sluggish response is fron the skyhigh inlet temps, not your water temps which are probably still fine. you running pods or airbox?
Engine fan is mounted to the water pump not the air con.
Edited by GTR1993
Whilst that is true, the fan on the front is for neither the engine (normal operation) or for the aircon. It is an overheat fan set to start when the engine temp becomes too high and runs as an emergency fan.. It can be easily wired to run as an assist fan for the aircon as well, but that is not its designed purpose.
To the OP, turbo cars are more susceptable to increased ambient temps compared to n/a cars. You should see a noticeable difference in performance.
Check your cooling system anyway, make sure that it is in good condition, good coolant /clean radiator /hoses ok /thermostat ok, usual service stuff needed if you want your car to be reliable in summer conditions.
Edited by heller44
As you know turbocharged cars hate the heat.
I think from 16 to 22 degrees C, is the best temps from what my mechanic told me, but for me colder the better.
If you want, make a heat sheild and I think R32 GTRs have a snorkle, that should be underneith where your pods sit.
Mine has one but it looks like an aftermarket job, with all the cut out marks in the plastic.
Just make sure you have your engine oil and radiator fluid topped up and take your car to a car wash and high pressure hose your intercooler cuz you will get abit of Heat Soak that way.
Thanks for the tips guys, I feel bad driving the Line in hot weather!
The car has recently had it's oils changed, and a few months ago I had the coolant flushed and replaced so I think that should be all good for now :banana:
Just want to make sure it's being cooled appropriately in this hot weather.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
