Hey all, i have an R33 GTS-T and recently it has been starting quite wierd, ususally i turn the key give it the sufficient amount of cranks and presto shes going.
As of recently i will start her up i need to hold they key cranking for a bit longer to get it going. If i let go at the amount of cranks i would usually let go at it feels like its going to stall or does..
-Car is stock no recent mods put on.
-Recently changed the battery and checked the alternator, i thought the battery was what was causing it originally but it seems not to be the case.
Does anyone have a clue as to what it might be as im puzzled??
https://www.sau.com.au/forums/topic/239896-starting-is-wierd/
timing isn't right.... check that it is set to 15 degrees or take it to the work shop that did the service...
bit of a noob mate lol, how would i check if its at 15 degress?
Also could it be the starter motor on its way out?
Edited by MP_R33
you need to use a timing light... it fires a light every time the No.1 cylinder fires, you aim it at the harmonic balancer. The balancer has markings of 5 degrees on it and there is a mark on the lower timing belt cover.
best to get your mechanic to check it...
Ok awesome. really appreciate ur help :)
Just a scenario, lets say it is the timing belt thats off, is it really doing any damage to the car or is it just making it harder to start?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
