  • Replies 51
nice buy mate! :)
but seriously, those lights need to die in a fire. as for wheels, meh, so what if everyone has doriteks, they look decent and they fit, so why not? and damo has a set for sale for fair cheap, so it might be worth looking into.
1998 is probably compliance date
nope, engine capacity - 1998cc is 2L
sorry if it's been pointed out.. cbf reading whole thread :)
buy these, much more sexier than doriteks ;)http://www.nissansilvia.com/forums/index.p...p;#entry4573927
Edited by M I K E
sorry if it's been pointed out.. cbf reading whole thread :D
buy these, much more sexier than doriteks :)http://www.nissansilvia.com/forums/index.p...p;#entry4573927
Its an SR, so it fits?
Yeah, those rims are baller :P but would look good. Dont buy my rims unless your planning on a brake upgrade, lol
Edited by Damo_R34
Yeah, those rims are baller :D but would look good. Dont buy my rims unless your planning on a brake upgrade, lol
every second person that gets a new sr s13/180sx thinks the build date is 1998 over on ns.com :P
Edited by M I K E
I guess I fit into that noob section :)
Just checked, it is 1998CC (stupid me) and was made 1995/07. I never really looked too closely at the plate and it was the previous owner who pointed it out to me and said it was the build date.
Rims are still a while off, hardly have enough money to pay for stamp duty OR insurance!
First will probably be side window visors, head unit, Type X spoiler, and either tint current lights or get Type X lights. Not in any particular order.
I just need to wait for my bank account to build back up again.
PS: I love my car.
Hey Nathan, I got it sorted, what I thought was the year was just the engine capacity. I was told it was the year but didn't look close enough. I did FAST it and that matches the 95/07 build date I found.
Damo I just like the looks of them. Not sure how/if it'll effect driving or vision, but I love the looks of them, as long as they're the proper ones (and not just the simple fold over type).
Not like you can see much, but I know there are some dodgy ones, I like this kind:
Edited by Thomasino
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
