okay guys. I was looking through the forums today and I spotted this picture of a skyline with major cosmetic styling. What I want to know is what you guys think of it and if you can identify the type of skyline it is. Im having issues cause of the amount of styling on it. Reason I want to know is that Im thinking of getting a skyline and going all out on it, preferably an r34 gtr and I like the look of this one. Was thinking maybe try something like that when I get mine (or if I get mine :) )
This is the Skyline
https://www.sau.com.au/forums/topic/240055-opinion-on-this-skyline/
  • Replies 52
Posted Images
i see the photoshop cause of the aero styling on the door, but I was thinking of getting the body custom made depending on everyones opinions. Yes I have the money (or can get the remaining) because I dont spend it on anything else as Im in the army (everything else is paid for). My only issue with it is the door, which would make it impossible to actually open the car.... which kinda sucks when you actually wanna use it. Do you guys think it is too ricer? And no Im not just looking to mod the body. Im hoping to put about $50-$60 grand into the engine and performance.
u could prolly have the doors like that if u make them suicide doors....
If I had the cash why not. Mate if you love it go for it. It will be ur ride not ours. Its been my wallpaper for few days now tho lol. But yeh it will be even sweeter if it can walk the walk (performance). Just do it and think about it later :bunny:
god I hate these threads, what do I care what you do to "Your" car... If you like it do it, If I can help in any way ask, but don't say "Will you guys envy me/still like me if I do this" ffs
I think it looks very unique... and f'ing expensive...
yup, that much i gathered. but (and dont take this in a disrespectful way), if you hate these threads so much, why do you still go to the effort of clicking on them.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
