Price was a seperate car company... back in the 1960's! Then Prince merged with Nissan to make babies (Nissan Prince) in the mid-late 1960's. That's why you can find cars like the Nissan Prince Skyline R31 which is some special edition with all different bits and pieces on it.
I've got Nissan Prince Chiba Racing sticker on my boot - searched Google to see what the hell it meant and it just came up with an address for a company in Japan. The company is a car dealer!
  • Replies 104
Posted Images
yeah i hate that. when i'm at the lights and have pole position, start driving and f**k all happens, haha.
ahahaha , then you think something is wrong with your car ,
then you find out its just the mats LOL
any of you southern blokes wanna help me get ont he cruise?? i'll be in the shed tonight getting my injectors out and ready for petro-ject to hopefully fix em up tomorra then straight back in the car + rego for the weekend :P
haha, i had it happen the other day, a wine truck dropped its load on Lonsdale Highway at the lights before the 100 zone heading north, and i was coming from shephards road, anyway the cops were directing traffic and i gave it gas, the clutch was down, the exhaust was giving the cops a show and dance but there wasn't enough gas to get much movement, i was thinking "f**kf**kf**kf**k"
any of you southern blokes wanna help me get ont he cruise?? i'll be in the shed tonight getting my injectors out and ready for petro-ject to hopefully fix em up tomorra then straight back in the car + rego for the weekend :laugh:
i would help, but i'm not all that knowledgeable on my way around an engine bay, i can point at things and usually give a name but that's about it.
however if you need manpower i can help you, may ask for the same in return refitting a stock front bumper though :P
I've got a "Prince" sticker on the back of my Stagea :P
I've got a "Prince" sticker on the back of my Stagea :banana:
it goes with your backstreet boys sticker roo :laughing-smiley-014:
wanted to go on cruise but car still at crash shop,what a bl##dy story,sgic insurance can jump
any of you southern blokes wanna help me get ont he cruise?? i'll be in the shed tonight getting my injectors out and ready for petro-ject to hopefully fix em up tomorra then straight back in the car + rego for the weekend :banana:
injectors out, hopefully into petro tomorra :P
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
