  • Replies 104
Posted Images
any of you southern blokes wanna help me get ont he cruise?? i'll be in the shed tonight getting my injectors out and ready for petro-ject to hopefully fix em up tomorra then straight back in the car + rego for the weekend >_<
haha i just round the corner too mate,msg me if ya need a hand still,hell ill even walk around the corner to yours for the exercise haha.
would go, but it depends if i can find an angle grind to cut away the front bumper so i can start driving my car again :D
What sort of front bar is it mate?
I have a s1 and i didnt have to cut anything off my stock front bar
the only thing i did was cut the middle bit to allow for more cooling for the cooler
apart from that i didnt have to do any hacking lol
Post pics if you can
thats wierd
how you have a s1 front bar just like mine and yet you have to cut yours to fit and i dont
interesting.....how big is your cooter?
mine is a trust/greddy one and it fits beautifully
could be
but still it shouldnt be that much
just wierd tho
the only reason i ask for his cooler size is that if mine were slightly bigger then the front bar would have to be modified
good luck with it Daniel
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
