Hi, i get a rattling sound -I think its coming from my exhaust- at about 40k's.. when im revving it.....
when its on neutral it doesnt make the sound, only when im driving... i recently got my cat converter replaced so its not that, my muffler replaced (i thought it was that but it wasnt) so now i have no idea what it is and my mechanic doesnt know either.. any ideas? thanks
You would think itd be something like that, theres not much else it could be if its comming from lower areas near the exhaust :S
You said you replaced the cat and wasnt that, did they check the piping from the extractors etc? maybe something isn't holding/stuck there.
But the word rattling in general is quite broad without hearing the noise for ourselves...is it a deep rattling noise? A tinny rattling?
I don't know much myself but if it doesn't happen when your idling but happens around 40km/h and continues it could just be that a section of piping is loose and not held in place properly, and when more pressure is passing through, the noise therefore occurs??
I could be waaaay off the mark. Goodluck hope you get it resolved soon!
mines doing the same aswell and its a r33 like all of you, i sware it comes from the gear box........
i think it is bearings somewhere that are worn down?
the sound and where its coming from sounds like a bearing, are all of you getting the same rattle from the gearbox thats really deep at 1500rpm and once it hits 2000rpm its more of a quiet tin rattling sound then stops after 2000rpm.
anyone confirm that they think its bearings now
yeah. sounds like a deep rattle O_O it sounds like its coming from the exhaust to me (but it aint cos i got it checked out) Anyone HOW MUCH DOES IT COST TO FIX MORE IMPORTANTLY? aNYONE KNOW? APPROX?
I'm getting the exact same problem in my R33 SI GTS-T..
I just finished installing a FMIC (which was a bitch, damn clamps flying off) and only just started noticing it now that I'm listening extra carefully..
I did some diagnostic and noticed that if I push my clutch in while it's rattling the rattling immediately stops. I was in second gear, stock ECU.
Edited by Alinys
if it stops when you put the clutch in it could be the trust bearing but id be dam soprised if you could hear that making noise while ur actually driving! when sitting there ideling you can normally pick it because it will sound like something mechanical rattling around and when you push the clutch in it stops.
but i doubt it would be a thrust bearing.
changing the clutch and all components of the clutch soon (after my 50thou rebuild is back together in a week :P ) so ill soon be able to see if it helped me or if its a problem that nothing to do with manual and auto differences. it might be the cat r the muffler because there relatively close to the gearbox to be mistaken because its just a crazy noise =\
i got the same problems, with the stock muffler it was loud on take off. it rattle hard.
thought it was a broken muffler so i got a a cannon it was still there wasnt that loud tho. i was thinking it was the cat or the resonant
seriously its going to be the clutch or gearbox. THE SOUND IS A DEAD BEARING!!!!!!! thrust bearing probity auto or manual i guess its got to be the same component, that is if were are getting that noise that we all say we have. someone take phone and record it. my car has no engine in it at the moment because of mods so i cant :)
I think you will find that only manuals have a thrust bearing as it only works when with the clutch, i know the noise im talking about is not the thrust bearing as that is making a different noise :)
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
