good on ya mate. Info?
Kristian imported it for me (mr iron chef)
as for cost. depending on how much compliance costs me, somewhere between 13-14k all up.
its a
96 M-spec
63,000kms
Manual
Sunroof
ABS/Hicas/Active Lsd
Koenig 18 inch wheels
fmic of some sort
suspension
kakimoto exhaust
bride seat
gtr wing
rear pods/side skirts/front skirt
blitz sus pod
strut braces
...thats all i can remember atm
Things that went missing on the way: Remote for alarm (what the) Space saver spare and an emergency flare.
(haha and yes Son. still got the GTR badge)
Edited by AFTDRK
https://www.sau.com.au/forums/topic/240475-my-new-car/#findComment-4199894
sold it to a member on here Kiet :kiss:
what about you man, what you drive these days...
pity i never got to see your Gtr.
yea missing the 33gtr so much ='( driving a r32 with 34 front now although atm its at smooth garage gettin a new engine and turbos, etc etc.. lol hope itll make 200-230ish kw ^^
https://www.sau.com.au/forums/topic/240475-my-new-car/#findComment-4200146
lol, me loves engrish:
"This Skyline is very cool and good condition. The rear style is GT-R looks. And it has not accident career. And the mileage is a little. We did maintenance well. You can sell your customer this Skyline soon when you get this."
it looks a shit ton better here: http://www.tradecarview.com/used_car/japan...+coupe/1120904/
https://www.sau.com.au/forums/topic/240475-my-new-car/#findComment-4201944
nail polish remover gets that paint off the window really well.
it looks like someone replaced the whole boot lid and spoiler from a 33 gtr to your car ;)
goodluck with it. get a space saver before you go through regency or you wont pass!
https://www.sau.com.au/forums/topic/240475-my-new-car/#findComment-4202620
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
