Hey everyone,
Well it's been a while since i have posted on this forum but i thought i would share with you guys my recent aquisition. I have bought a complete HKS 3037 pro S Turbo/kit off of a fellow member along with a Z32 airflow meter. All i'm waiting on now is a bit more funds and some Nismo injectors/Fuel pump.
So in approx 2-3 weeks time i'm hoping to ring Martin Donnan and book in for a tune...Cant wait should be a bit of fun thats for sure, hoping for around the 250ish rwkw @ 16psi.
Cheers
Lee
https://www.sau.com.au/forums/topic/240494-hks-3037-here-i-come/
  • Replies 143
great turbo to have purchased.
I have one on my JZX81 1JZ-GTE. awsome torque and great power throughout the rev range.
Mine makes around 290+rwkw on 16psi.
Then again my engine has a few more toys inside and out.
Will be keeping an eye on your posts to see what you get out of it with Martins skills behind it.
Goodluck
wanna fit Z32, gtr injectors and resistor pack for me then tune it somehow??
i got a e-manage blue
can u pm me a price please mr.donnon?? i got a R32 gtst
i would call but i dont have your number lol
Lee if that was you that called me today, the once again good choice >_<
We have Australias quickest and fastest Skylines on both drag strip and circuit, so you are in good hands :D
Hey Martin yeah that was me i was more than happy with my last tune you done with standard turbo, can't wait to get this new one on and tuned. Oh forgot to add i may need you to wire up my AFM also but everything else will be installed and ready to go.
Cheers mate
Lee
Goodluck
Thanks mate i'm hoping for a bit extra torque and reckon this turbo fits the bill nicely with room to move later down the track when i go forged internals etc. I will definately keep everyone updated.
Lee
hey martin.
wat u charge for pfc tune?
+1 to adrians ??
i am thinking of getting a tune soon
just waiting on injectors, z32 afm and turbo
so i would like to know how much will it be for a full tune
thanks Martin!
his old partner (Uri) from the Fueltronics days is coming over to my place tomorrow to have a look at the ignition issues on my bike......hopefully it's an easy fix
Hope you get that problem sorted Pete. Summer is coming and Ive already had some good rides ... [just to spur you on a bit] :/
Thought i would give a quick update on progress as i received the turbo yesterday (cheers Nizmo_Freek). I have taken the car to get turbo/exhaust fitted and quickly run up under light load to make sure shes good to drive home quietly.
I will have clutch fitted up next week and order pump and injectors also. So all in all very happy with progress thus far. Expect a call real soon Martin.
Cheers
Lee
We tuned a 3037 on an SR20DET yesterday. Yes, the engine had pistons and rods to allow a bit more boost, but the results of the HKS turbocharger were extremely impressive....nearly 300rwkw on our Mainline, with more up its sleeve if need be :)
Thats excellent results for a 2 litre thats for sure thanks for sharing that info Martin. 250-260 should be obtainable with the old rb25 then you would think.
Cheers mate
Lee
Ok turbo is on (cheers Pete top job mate) AFR's fine under mild loads 11.5-12 so fine to putt around for now. Turbo sounds sweet when starts spooling a bit louder than stock thats for sure. Quite a bit of difference in visual size of turbos (standard turbo looks physically alot smaller). First impressions under light loads are not too much difference at all, still very civilised.
Cheers Lee
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
