  • Replies 51
parts still for sale:
rb20det complete
with big after market turbo ecu and looms $1000 o.n.o 85k supposed to have internal work
diff $150
side mirrors $100
4 doors rear right damaged $150
keys & barrel set $200 (ignition, doors
rear bar $50
rear reo $50
a/c condensor $50
wiper motor $10
all seats inc door trims $350
roof lining $20
interior lights $10ea
sunvisors $20pair
interior mirror $30
front windscreen pillar trims $30
rear upper trims-$20
skyline side step trims $30
center console $30
glovebox $30
cluster surround with gauges $80
brake setup $200 rear has brand new pads
steering column surround $30
carpet $100
under dash trim $20
all seatbelts $120
fueltank $80
steering column $50
rear cradle $100
metal dash support $20
power steering rack $100
skyline floor matts $30
windscreen $50
rear windscreen $50
3" turbo bak zorst $200
boost controller and boost gauge $50
18" work rims with potenza tyre
price drop on 18" work esperio rims
comes with 2 brand new street tyres and 4 semi slick potenza tyres
the tyres alone 4 these rims are worth 1500
and the rims are worth 3000
now selling 4 only 900 ono
need these gone to buy my car
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
