this is a bit off topic, but are there any dyno days, car shows or any SAU events around newy and the central coast?
something to get me out of the house at least :)
something to get me out of the house at least :(
You just missed out on Putty Road Cruise, was very good.
If u go to the NSW "Events" section there is a cruise to Newcastle coming up
something to get me out of the house at least :ph34r:
will run a tuning day in early Dec. and will fly Mark Jacobsen (Godzilla Motorsport...worlds 3rd fastest GTR) down to do the tuning. Have a brand new Mainline 4wd dyno to use just need a few guys interested to make it financially viable. Costs to have Mark and the dyno for the day to be shared between participants.
anyone interested?
anyone interested?
Im interested to come and watch...
and bakes i would like to see your car on a cruise or just around at that... its sooo good man
Thanks mate. If youre going down to check out Sydney Auto Salon in December you will be able to have a good look at it as it will be on display with the Skylines Australia crew.
Will do :banana:
unless we have interest there wont be much to watch.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
