spotted this arvo bout 3 i guess, think was tinks in the white 33 gtst, gtr wing, led tail lights. goin past green point erina lights... yewww waves :P
silver 350 gt up at kariong, got the plates but cbf writin em lol
maroon 33 gtst with no wing at the bottom of kariong, black n white plates
but yehhhhhhhhhhhhhh sum1 from here betta be in one of these
keep spotting an R34 GT, like a silver colour, green P plater, with a cannon n all that driving round n exchanging waves with me lol
spotted another green P plater 2day in an R31, white, big cannon, gave his gf the nod n got one back bahahhaaha
should flash em :yes:
ohh i saw that car a few times that night... ya shoulda come ova n said gday 2 us, there were only 3 of us left lol
haha yeah i was going to after i ate my maccas :P but then youze left so i was like ahh well... next week :P
yeah man , i seen krystal and brad on the foreshore last night too , was that you in can 2nd car park ?
yeah that was me hiding alittle bi in there lol there where a heap of cops out that night
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
