Spotted a white r33 along bridges road about 5:30pm today and got a wave from a white r32 gtst along acacia ave just after.
And my car shared a garage today with a midnight purple r33 gtr and a black r32 gtr whilst getting some overdue TLC :D
spotted a white 33 GTSt going thought west gosford to day
spotted white 32 GTR ( keith)
and i also spotted a black 32 GTR in hill street in gosford ( GODZILA) * THIS CAR IS TIDY AS*
spotted on the 12th of march a red 31 " QIK 877 " victoria plates, cruised with from wyoming to sparks rd exit on freeway... had RB25DET in it lol
spotted a white R35 GTR parked in hunter street newy couple of weekends ago too
spotted
1 x maroon R33 bottom of karions hill this morn 8:00
2 x maroon 33s1 & White R33 @ Wes gossy this avs 5:00
1 x maroon 33 gettn of the F3 Somersby, Fridy morn bout 8
that is all
Got waved by a silver R34 GTR with a black bonnet as I was going to Kotara Westfield bout 2pmish yesterday.
That was me. I was on a kotara westfield run too.
Dam your car was low. I was suprised when you headed up the ramp. I thought it would bottom out. Loved your exhaust note.
Aha, it's a tad bit low . Yup made it up the ramp with minimal scraping. The exhaust is quite flat now. :P
Herd you along bridges rd. Was wondering where that bov sound was coming from then I look behind it was you. Looks the goods.:thumbsup:
Spotted a black R34 GTR in Adamstown Sunday arvo... looked very tidy..
on another note.. Newcastle/Central Coast Members Hardtuned.net have a cruise on saturday night.. heres a link to the info.. hope to see a few of you there. Hardtuned.net Cruise Info
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
