Pretty sure i saw SLO33T ?pink plates,yesterday.Driving through Charmhaven heading towards Lakehaven.I was driving a black bug Sti if you saw me lol.
Hey, that's me. I don't remember seeing an sti but hai :action-smiley-069:
gave a wave to a clean looking white 33 with P plates on the new england highway about 4pm yesterday.
about 5:30pm was on the pacific highway cruising behind a maroon 32 gts-t (p-plater) and a silver 33. not sure if you guys knew each other but you were sure in a rush to get somewhere.
hey mate that was me in the marron 32 n my mate in the 33 :action-smiley-069:
ah so you were mates, explains why you were keeping up with him in such heavy traffic. enjoyed cruising along behind you guys, i could hear your bov a mile away haha.
haha yeah i dont have a bov , its blocked and just resurges thru the turbo just flutters its head off.
Spotted a white R35 GTR parked out the front of steve's motors on west street. Looked absolutely amazing. Definitely not the kind of car you expect to see in Umina.
Spotted R33 turning right off necastle road to crodice street , and at same time me in other lane turning right and spotted a silver V35 going straight in lane next to me !
Just spotted a purple r33 in the carpark at west's mayfield, a silver r32 gtr with a n1 front bar at the mobil/quix on maitland road and a black r32 gtr turning on to university drive from Maud street.
I was in my red commanfail yoot.
You don't happen to work in Waratah by any chance do you (for BK)
Ahh thought it may have been you, I seen your car in the carpark going back a while ago and is the only silver R34 I know of in Newwy, and seen you again last week (I drive a black Lexus IS300 with a C West kit with bronze Advans) You may have seen my work mates black R34 (bakes) going back just over 12 months ago in the same car park before he sold it!
Edited by DR-JEKL
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
