just letting you newy guys know i have a set of wheels for sale
http://www.skylinesa...mags-2-of-each/
also spotted neat r31 GTS1 in cessnock
Put it in our Newcastle thread mate :)
White 34 on the back of a tow truck at Cardiff
I hope mine is still in the shed :P
On that note -
Spotted a champagne 34GTT (Didnt know they made one that colour) near bar beach
Spotted a white 34GTR near the self storage joint on Industrial hwy
Spotted a white 35GTR at Super Cheap Auto in Raymond Terrace (Kurtis reckons he was there for a pod and boost gauge :P )
All of this was on Saturday.
red stagea at kincumber on the weekend, chick driving
Ha ha ha that was my wife. She stole my car so now I have to drive a 323. All because the pram fits in the back better!
Been spotting heaps lately, should really remember to post :P
Most recent one is the silver 33 with black rims and chick driving through Tomago/Heatherbrae.... Judging by the exhaust i am guessing it was N/A
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
