Hi all
I have a full set of r32 gtr brakes for sale including DBA rotors
Fronts: Calipers inc all shims, pins and springs, and DBA 4000 slotted rotors $450
Rears: Calipers inc all shims, pins and springs, and DBA longlife slotted rotors $300
Can include rear RB74 pads for an extra $75. Pads were bedded in and did 5 laps of wakefield.
Also have a full set of maltech braided lines to suit r32 for $200
or take the lot for $850.
I can throw in the rear hand brake assy (minus hubs) for people who are thinking of converting an s car for nothing if you take the lot or $50 if you are only after rears.
All prices negotiable to some extent. Lowballers will be ignored or abused depending on my state of mind at the time....
pics on request but they look like brakes, lines and pads......
Cheers
Dave
https://www.sau.com.au/forums/topic/240830-r32-gtr-brakes-and-dba-rotors/
  • 1 month later...
Sorry DJrift, fronts are definitely sold.
Ran into problems when trying to change emails and haven't received an email response back from an admin in close to 2 weeks now.
So i guess the old BHDave acct is dead.
Anyone interested please pm badhairdave rather than BHDave
cheers
Dave
  • 1 month later...
Hey would you be able to post some pictures up, fairly intrested.
Hi all
Cheers
Dave
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
