Hello all,
At the moment this is just an exspression of interest (so thats why its not in the for sale section) but I may be able to get GTECH metres very cheap. Im told they retail for $395 or there abouts but if the deal falls through and I can get my hands on some im willing to sell them brand new in the box for approx $220.
The price is not 100% confirmed but for the meantime ill go with that
What do they do?
* 0 to 60 mph time
* 1/4 mile elapsed time (E.T.)
* 1/4 mile trap speed
* Instantaneous lateral acceleration (G s)
* Sustained lateral acceleration (G s)
* 60 mph braking distance
* Instantaneous braking Gs
* Sustained braking Gs
* Horsepower
These babies are extremely accurate and are only about 0.1 - 0.2 off.
So im basically looking to see if there is any interest for them.
If you would like to get one at this excellent price post up and let me know and then ill take it from there
Thanks
UPDATE: PEOPLE WHO WANT ONE
paullys 32
adzmax
zandi2000
CONAN
PRO_32
T0nyGTSt
If you want one add your name to the list
https://www.sau.com.au/forums/topic/24087-gtech-metres-in-the-box-and-cheap/
  • Replies 41
At the moment I am looking to see how many people would be interested, if theres enough interest I will go ahead and order them.
I would require a deposit of $120 and then once I get them and give them to you, you pay the remainding $100..
Thats just insurance for me as you can appreciate I dont wanna buy all these items then people back out.
I would say I probably wouldnt be looking to do this for another 2 weeks or so
i have had one for about 6 or 7 years now....they are quite good and useful not to mention relatively accurate little things...
back then it cost me $295, but nowdays retail at $395..
i do recommend them.
Thats totally correct hippy! :)
Ok heres the latest
Ok guys I have a spreadsheet that I am using to put the names of people that are interest so that I can get a total of how many people want them
So far the people that want one are;
paullys 32
pushead
INASNT & Kamikaze you said maybe, if you want one let me know and ill add you to the list.
RiggaP they just plug into your cigarette lighter!! Very easy to use!
If you want one just post up and ill add your name to the list!
I have confirmed that the best price I can get them for is $220 as I stated ( I tried to get them ever cheaper) so this is what I have in plan
If you live in VIC
I will want to meet with you and take a deposit of $120 then once I get them, which should be within a fortnight of when i get the money I will meet you all again and give them to your and you pay the remainding $100
Interstate Members
For those of you that are interstate I will require that you pay the deposit of $120 to my bank account (Ill give you my details once I have arranged everything) and then I will COD them to you and you pay the Post Office $100 PLUS postage (which shouldnt be much at all)
If you want to add your name to the list or take it off for some reason let me know by posting here
Ill keep you all updated
Cheers
Ok man
Not a problem. Like iove said im leaving this open for about 2 weeks then I will meet everyone who wants one and get the deposit etc....
I have a list of MAYBE'S, for those of you that are there please let me know weather you want one or not
Thanks
I'm keen but I question their accuracy. I'm not seeing how something can measure distance by simply plugging into a cigarette lighter :confused:
I'll do some reading and get back to ya.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
