Hey guys
Okay long story short I toke off the head to get reco'd and the time it was away the water gallery’s got rusty on the block so when I bolted it up I had rust residue in my coolant.
My question is how do I go about cleaning it/flushing it out???
cheers
bill
https://www.sau.com.au/forums/topic/241030-how-do-i-flush-out-coolant/
Disconnect both hoses from the radiator and use a hose to flush water back and forth through the block, using both radiator hoses. Keep at it til she runs clear then let it sit for a while draining out the water so you're not diluting your coolant mix too much when it goes back in. I can't remember if the thermostat blocks the water flow extensively in the RB25 as it's been ages since I had one. Just see how you go. If you're going from the thermostat side and the water ain't coming out the other pipe then you may need to remove the thermostat also. Good chance to do the radiator at the same time. For a quick confirmation, give a local radiator/coolant specialist a buzz and make sure you're happy with the direction you're going to take. It's your car in the end.
Good luck :)
So long as you put the right mix of coolant back in and there's no leaks you should be fine. If any of the internal galleries or the radiator etc have suffered badly from rust then you may have some rust still in the system but the coolant should keep it in check. If in a few weeks after refilling with coolant the fluid goes brown again you may need to flush it all fully again.
Do it the first time and see how you go.
plenty of additives you can add to the cooling system, run it for half and hour then dump it, flush it and refill with new coolant. just have a look at the local parts place. repco, bursons etc.
there is a drain under the turbo you can undo, but it is a bitch of a spot.
my advise, remove thermostat housing and thermostat when you want to flush it with the hose, otherwise the thermostat will block the water from draining out.
other option is to pop off a heater hose at back of engine.
whatever is easiest really.
Just make sure you 'reverse flush' the system. i.e. flush it in the opposite direction the water normally flows. And make sure you reverse flush the radiator, block and heater core separately to avoid cross contamination. Personally i think a flush gun is a must.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
