Hi all i know this has probably been answered somewhere on here but couldnt find it...
Have these coilpacks been made yet?? If so, where can i buy them from (either locally here in SA, or on the net, i have checked kudos motorsports with no luck).
If these haven't been made yet, where can i buy Splitfires for my car from? (once again net/SA).
Cheers
Dan
https://www.sau.com.au/forums/topic/241075-twinspark-for-1998-s2-r33-gts-t/
Ok i'll try again...I meant to say superspark.
As in, the only superspark coil packs i can find are for PRE-1995 R33 GTS-t's only.
Is there a version for POST-1995 models yet? I know there was previously discussion about the (hopefully) imminent arrival of these packs
Cheers
Although they claim to be the only ones to increase spark over and above the OEM one
So basically like having a HKS Twin power + Splitfires but all in the one neat package <- Can anyone back this up?
I would prefer a green one in my pocket and go the JJR's though :rant:
For $500, there is no way its the same as a HKS DLI + Splitfires(or stock coils)
You need replacement coils either way sometimes, and the DLI is additional cost ontop.
I think Splitfires 'claim' it too, but it was tested by two people on here a while ago, and it was virtually nothing different
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
