Small rant from me.
Contact a guy in Melbourne re. buying his GTR and a deal is struck.
Sent of $1K deposit as a show of good faith and tell him I will be there Wednesday10th.
Rings me today and says that unless I can get there before Saturday he is selling the car for $500 more to a guy coming from Sydney.
I had already booked tickets etc to fly there from Adelaide and reiterated that he was happy with the price 4 days prior and that the guy from Sydney had sent nothing except promises.
All to no avail. He promised to send the deposit back which I should get Friday.
Thing that shits me is I thought that once a price was agreed and a deposit paid , the deal was done and this is how I have always conducted my business.
Bloody annoying !!!
So anyone know of any worked GTR's in Melbourne around $30K
* Rant off*
Cheers
Ken
https://www.sau.com.au/forums/topic/24114-hows-his-form/
If it went to court along with the email printouts , I may have a bit of a case but the only winners are the lawyers.
No , I will just write it off as a bad experience. Mind you , if the deposit does not get returned , I have the plane ticket and I know where he works....
Cheers
Ken:D
https://www.sau.com.au/forums/topic/24114-hows-his-form/#findComment-516192
Ken, im studyin contract law this semester and if u haf email agreements, and he agreed to sell you the car at a particular price, and you sent a deposit, your deposit if your consideration for his promise to sell the car @ that price and i can quote u at least 3 cases that are exactly similar in facts to yrs and the ratio decedendi is that.....
the guy has to sell to you!!
https://www.sau.com.au/forums/topic/24114-hows-his-form/#findComment-516341
Originally posted by adam 32
once the deposit is down do you have any legal claim to the vehicle?
As said by Streamer, the guy is locked into the sale once a deposit is laid. That's the point in a deposit.
I heard through secondary sources that something exactly the same happened recently in our own lovely Perth, went to court and some reimbursement was settled, covering court costs too.
Was it with anyone on this forum?
Sorry to hear mate!
https://www.sau.com.au/forums/topic/24114-hows-his-form/#findComment-516364
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
