I dont want to lose my pod cause to me its not a turbo unless i dont have that sucking noise and flutter.
You can still hear suction and flutter through a high flow panel filter. The intercooler does amplify these sounds. Sure, these won't be as loud as they would be with a pod but they do get noticeably louder after you install that cooler...
  • Replies 41
thanks everyone for your opinion i guess ill go wit hiding my frount mount and try with a normal air box see how it sounds if good enough ill keep it if not go wit the pod.
^ Good Job
Although it still looks as if your hiding somthing :)
then again, a cop doesnt have the right to touch anything in your engine bay so technically cant prove if there is a pod under there..
Edited by willL
well I better not..
since I'm already at 60% warning due to someone elses power trip issues.
tough break lol.... i nearly got a warning because some fool took what i said the wrong way TWICE, then i got pissed off and replied for everyone to see after night shift at 1am in the morning lol....
I made an airbox for mine, Just outa sheet metal, then finished with crinkle coat so it looked stockish, then clark rubber 'pinch weld' for edge protection. :)
say i had the seet up that duke has,,,,, the box looks legit but i have a fmic thats not engineered,,,, copper pulls me over and defets me for the fmic,,,,, when i take it to get inspected and get the defect removed could they (rta i supose, whoever checks the defected car) then keep the defect notice on because of something that the cop mised,,,,, like the pod or bald tyres or another defectable item????
Haha, yeah, :)
Here in WA your allowed pods but they have to be secure, mine is loose as...
Iv'e got something to secure it with but haven't gotten around to it.
but it's outa sight, outa mind from the police atm, lol
^ Good Job
Although it still looks as if your hiding somthing :P
Hmmm, why exactly do you want to keep the pod filter?
I see it as:
Performance? Without CAI it's not so great.
Legal? Well no, prepare for a defect in most states if you've got the intercooler as well.
As per previous answers you could use the stock airbox which will hide it, but you've still got a fair chance of getting defected for it, so it's your choice if you want to play it safe or not.
Getting a black intercooler may help too, but its not exactly foolproof :P
So obviously you dont want the pod for power, the set up your planning to go with will lose you power, the jjr stealth intercooler set up uses the standard ic pipe holes, normally thats where a pod will draw its cold air from, with those blocked all your engine is ingesting is hot air from the engine bay.
^ Good Job
He doesn't have to touch anything, thats not the issue.
The officer simply sends you to the EPA and then you'll have to prove to them whats inside it.
keep your stock airbox handy in the shed, lol :D
Just outa curiosity:
Do the cops seriously do that in Vic?
Also, why is it an EPA issue over there?
Over here it's the DPI that deals with you and they only right a list of your defects and tell you to fix them or permit them. It's only if they catch you gutting your cat that they'll get narky but you'd have to really piss them off for them to actually do the paper work to fine you, haha
Yeh they are that bad man, its hopeless.
The EPA is Aust wide, yet the laws they enact upon are only drawn up by our lovely local Gov't. The laws are from 1992, and so out of touch with current cars, mods, emissions and so on that its not funny...
But alas, the police dont care, they dont get paid to :)
EPA is worse than whatever your road worthy body is. I believe you guys can get engineers papers for each mod.
Over here its two tier.
EPA = emissions and anything that might affect them (no matter how ridiculous, like a pod/IC, doesnt alter emissions dick all, but its illegal)
VicRoads/Engineers = modifications/mechanical and so on. Brakes/suspension/engine conversions - that kinda stuff
somebody answer this question who has had experience or knows the law in nsw for it?????
True, I guess you have the time to put stock box back on before epa test, but theres still the hassle of going to get EPA check etc etc.
Pods fine here in QLD as long as its secured down, not flapping about. Mate of mine is getting his car looked over has front mount, high mount turbo, pod, waste gate. Just has stock suspension put in wheels with good tread (borrowed my 9.5 rears and 9 fronts. ) and they let him through fine. Only hold up is that he doesnt have a engine number lol.
You will only have to change it if they tell you to but as long as its secure then it should be fine.
What do you guys think if I get that stealth just jap cooler paint it blak and put blak mesh in the front bar in the opening. I rekon that would be prety hard to see especialy at night and also considering the cooler uses the stock pipes. I dont want to lose my pod cause to me its not a turbo unless i dont have that sucking noise and flutter. what u guys think?
1. Record the sucking noise and the flutter.
2. Get rid of the pod and fit the original airbox and snorkel with a high flow panel filter.
3. Play the sucking noise and flutter through your stereo.
Bit rough don't you think?? :)
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
