Service & Buffing?
Guest CleanAndSimple
Hey guys,
need a good place to get my car serviced, (that wont tell me i need this that and the other when i tell them im going to regency)
also need a place that can do buffing (got a whole bunch of swirl marks. and marks on sideskits from my F**king work boots (changing shoes in future) lol
cheers guys.
Edited by CleanAndSimple
https://www.sau.com.au/forums/topic/241332-service-buffing/
by wont say i need this and that i mean like saying i need radiator hoses when i dont :D get my drift :D lol.
thanks mate but im looking for a mechanic place that can be my car servicer :(. i have one, i just dont know if i trust him now that ive moved up in the world of cars :) lol
only 15 days till i hopefully "crossed fingers and toes, and touches wood" get threw regency. then i shall be comming to cruzes if i can figuire out how it works ha
https://www.sau.com.au/forums/topic/241332-service-buffing/#findComment-4212677
I'm a new car detailer, but I don't charge any less than $200 to buff and deswirl an entire car.. I've found most people that drive imports think that's rediculous, but it takes me at least a whole day - especially on black.
https://www.sau.com.au/forums/topic/241332-service-buffing/#findComment-4212922
I can service your car for you, if your after a general Oil, oil filter, coolant, plugs, timing check and whatever else you want doing and i wont say shit about anything else about regency if it makes you happy hehe. Use all genuine parts.
Ryan, I'd like to have my timing checked if you can do that. I have my own timing light, but obviously there are no leads to clip it to. Damn RB motors :D Might also change my plugs too ... I have a set of iridiums ready to go.
https://www.sau.com.au/forums/topic/241332-service-buffing/#findComment-4212933
Kev,
The SP23 is out of lease soon, and I want a full detail to prepare it for sale (buff, interior detail including condition the leather, and engine bay cleanup) How much to do that? Yes I realise it may be a few hundred but can make the difference when it comes to sale ;)
Cheers
Lee
https://www.sau.com.au/forums/topic/241332-service-buffing/#findComment-4212940
^^ theres a loop on the coilpack ignitor you get your signal from to check timing :)
That doesn't give a correct reading as it's intented for the Timing lights that Nissan use. You need to take no1 coilpack out and run a lead (any normal lead) between the coil and the spark plug, then you will get a true reading.
https://www.sau.com.au/forums/topic/241332-service-buffing/#findComment-4213719
Righto, that was my next option. But I don't have anything with a lead to donate for the timing check :D
https://www.sau.com.au/forums/topic/241332-service-buffing/#findComment-4213948
yeah as ryan said dont use that loop at the back it doesnt give an acurate reading (gives me exactly a double reading)
Their is an image of the loop to use in SydneyKids timing belt how to some where.
You can actually just slide the coilpack cover back a bit and get the light onto number 1 coil pack somehow and move it around slighlty and youll eventually pick it up with an inductive timing light ruby. Give me a yell some time if you want i did my own timing belt and managed to get a reading from it this way to make sure all was sweet once it was back together (checked timing prior and after belt change)
https://www.sau.com.au/forums/topic/241332-service-buffing/#findComment-4214011
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
