My GTR is in need of an engine rebuild and has been sitting in a work shop for months so far engine piping is off and thats all.
This guy is charging $750 for remove and refit of the engine. Any one know where I can get this done at a similar price as im thinking i might just ship the engine over to Dirt Garage for the build so it actually gets done.
Edited by Crans
https://www.sau.com.au/forums/topic/241386-remove-and-refit-rb26/
Dirt Garage quoted 7k for the rebuild the others were all 10k+ for the exact same build so will 100% be sending it over east.
Any idea on how much it will cost for the remove and refit i've heard they were all charging $2500?
2.5k sounds rather excessive when I got quoted $800 to remove/refit the engine in my old lady's 911.
I've done many engine in/outs on skylines and skyline powered vehicles and it is nowhere near as hard as the stupid complex German car.
You can get a brand new motor for around $12,000 as per the photo in Perth which would have to be better then spending $10,000 on a rebuild of a 15 year old motor, even at $7,000 plus freight it would be worth looking at stretching the budget for a new one.
The $7000 engine he will be getting will be much better than the one shown and its almost double the price. Its still got cast pistons, stock rods, stock crank, stock head, head gasket etc. Ill grant it does have the N1 block and pumps...but not much else. N1 crate engines are good in a street car at low boost levels but not the option to go if you want to make decent power.
$1500 is what i charge to R & R the engine...so use that as a guide...$2500 even at a rate of $100 an hour is 25hrs labour to do an R & R...they either have no idea what they are doing or no morals by ripping you off.
Edited by DiRTgarage
If it were me i would be taking it to Dirtgarage
Have a search and see his work, that many people on these forums get this guy to rebuild their engines. They seem to be very happy campers from what i have read.
Good work buddy the day i need a rebuild i know where i want it done.
no offence dude but a GTR engine removale is a sh*tload more complex than a simple gtst removal with the front driveshafts and all the other bulky bits attached, theres a good few hours in it each way.
pattygtst i think your forgeting something, Paul is in newcastle sydney. Crans started the topic on removal/refit
there are plenty of more than competant shops in perth.. tenagah,ovaboost,x speed, all star, hyperdrive.. just to name a few.
i removed the rb26 from my gtr in 4 hours and thats on the floor in a 2 car garage with no hoist, a workshop shouldnt take any longer as they got the hoist and that makes life alot easier. As adam said the 4wd side of things adds abit of extra work but not too much really.
I would offer a hand myself but i am in the middle of a couple of builds at the moment
Our record is 1 and 1/2 hours... but the race car is a little easier than a stocker and we use a hoist for the car and a forklift with a sling for the engine. :)
if crans fly's me over ill do it for $2500 :D
Dude, I know this - done the 30 in and out of the gts4 :D
Edited by bubba
Should be able to get return flights for under $400.. take that off the 2.5k, $50/night motel room, 1.5k for the r&r and you should still have some cash left to take DirtGarage to the strippers and get him pissed :D
OK Car is comming back home Monday yay :banana:
And i just purchased a second hand engine with HKS 2510 turbos on it.
Gonna do an engine swap and then start building a 3L.
Will use the old head for my drift project or just sell it as a rebuilder
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
