Hey guys
Have been thinking about getting my car on to the track and two questions are burning a whole in my mind.
number 1 - is it worth replacing the stock radiator??
My car makes about 205 rwkws @ 13psi, so its not hugely modified, yet its not stock either. I have been looking at the cooling pro radiators from just jap which are alloy and 60mm thick. They retain the factory shroud and id just be using the stock clutch fan.
Do these perform much better if at all than the stock r33 radiator?? and also is it even worth replacing in the first place? as my stock radiator works perfectly fine to my knowledge anyway. i just dont want the car overheating.
and question 2 - oil coolers.
i have been looking at the cooling pro ones once again from just jap, they seem like pretty decent quality?? (one of the 11 bar kits including filter relocation)
Also since i have bugger all tools at my disposal at the moment, how much would you imagine it would cost for someone to fit an oil cooler for an r33 series 1??
my car is 95% a daily driver, im thinking about having a few spurts on the track when the oppurtunities arise, i really just want piece of mind about the temps in the engine bay if i do a few hot laps.
same kinda deal with the oil cooler??? any money i can save will be going towards a turbs upgrade and coilovers as well :D:(
i guess best bet may as well be just bomb it round the track a few laps and see how high temps get. next track day around my way is in december, so the hot weather will really test it!
Oil cooler is good to get.
Are you running the stock turbo @ 13psi? If so, for track you really need to back it off.
Otherwise you will kill it just due to the heat that track brings, the rear wheel wont take it for long at all.
Some people's have died on their first track day out :D
Some people's have died on their first track day out :/
What are the temps of the oil that people reach out on the track?? I personally have never seen over 88degrees in my car.
Higher than 88 thats for sure.
10-20mins on a track sprint is nothing compared to even a spirited squirt on the street...
Given brakes probably wont last more than 3-5 laps before requiring a 'easy' lap or two before getting up it again...
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
